Latest post Fri, Jun 12 2009 11:02 AM by general_failure. 3 replies.
  • Mon, Jun 8 2009 7:29 PM
    Batch Capture problems, how to force media relink? HDV DIG_TOO_SHORT
    I am recapturing deleted footage (media files) on a project that has already been logged, edited, etc. I am doing the batch capture off the same camera I used to capture. Sony HDV 60i.
    Some of the clips capture fine, others give me a DIG_TOO_SHORT error or INVALID_TRIM
    I´ve read previous posts about work arounds (setting capture to capture over timecode breaks, etc)
    But when those work arounds don´t work, what is the best way to relink media?
    For example, I could:
    Start capturing at the in point and then manually stop close to the end point. Is there a way that I can ensure that MC would recognize this clip as the same media that I had before? In other words, so that media would show up on my timeline, automatically?
    in other words, WHEN BATCH CAPTURE FAILS, AFTER ALL WORK AROUNDS ARE EXHAUSTED, WHAT IS PLAN B TO RELINK MATERIAL?
    Any suggestions, recipes, etc would be greatly appreciated. Thanks!
    Also, it is now cycles through each list of clips to capture 4 or 5 times before stopping. The first time it might say that the capture was successful but then it changes to that it was skipped. Weird!
    PS: this is the error log from the console:
    Batch Capturing Section (00;41;39;05)-(00;49;26;20): 2 clips
      * Batch capturing Media to volume (D:)
     Discontinuous TC base tolerance = 6
    Audio sample rate of incoming media is marked as 48000
    Only captured 7455 frames out of 14009 frames.
    DIOProducer captured 5854 frames. Average frame size is 244.2KB.
    Storage consumed at the rate of 2m:23s per gigabyte
    BatchDigitize - 1 clips digitized out of total 2
    BatchDigitize - clip 1 TOO_SHORT - master 7364, digitized 870
    ***!!!*** Batch Capture Aborted.  Media Discarded.
    Error on clip 'futbol f 5.19':
    Exception: DIG_TOO_SHORT
       Batch Capturing Clip :: futbol f 5.20
    DIOProducer captured 2758 frames. Average frame size is 244.2KB.
        Batch Captured Clip :: futbol f 5.20
       Batch Capturing Clip :: futbol f 5.21
    DIOProducer captured 699 frames. Average frame size is 244.5KB.
        Batch Captured Clip :: futbol f 5.21
       Batch Capturing Clip :: futbol f 5.22
    No frames recorded.
    BatchDigitize - 0 clips digitized out of total 1
    Channel: Channel not configured.
    Error on clip 'futbol f 5.22':
    Exception: Failed to find pre-roll point on tape.
    Batch Capturing Section (00;54;20;06)-(01;00;54;17): 2 clips
    No frames recorded.
    BatchDigitize - 0 clips digitized out of total 2
    Error on clip 'futbol f 5.23':
       Batch Capturing Clip :: futbol f 5.24
    Exception:
    @ Mon Jun 08 19:07:53 2009
    Exception: Capture aborted due to lack of progress
    DIOProducer captured 4084 frames. Average frame size is 244.2KB.
    BatchDigitize - clip 1 TOO_SHORT - master 9757, digitized 9737
    Error on clip 'futbol f 5.24':
    AVID MEDIA COMPOSER version 3.0 Windows XP 2000 3.5 gigs Ram, firewire connection Processor: ADM Pheno x 4, 64bit, 2.4 Gh2 Trued QuadCore, 4.0MB total... [view my complete system specs]
  • Thu, Jun 11 2009 12:28 AM In reply to
    • flicmaker
    • Posts 24
    • Points 330
    Re: Batch Capture problems, how to force media relink? HDV DIG_TOO_SHORT
    Recapturing HDV is a pain in the backside, so you have my sympathy.  What I have done in the past when faced with the same problem is to open a brand new bin, crash record the clips starting before the previously logged in point and stopping after the logged out point.  Then once you have these new media files, select the sequence and relink it to the new media.  I have never been able to batch re-capture HDV and get it to link to the original logged bin entries.
    Flicmaker
  • Fri, Jun 12 2009 2:20 AM In reply to
    Is this the same problem described in your previous post?
    Did you try the suggestions presented to you? Maybe it would be less time consuming capturing
    the entires tapes and then relink.
    For the present time there are no new fixes to adress this problem, probably folks at Avid
    are evaluating this, as many users report it.
    Good luck
    P.S - On a side note, I usually work in large Avid systems with Mojos and Unity for several production companies.However , I have my own home Avid System. MC 3.5, no Mojo, no qualified hardware except a Quadro card.
    I usually batch capture using a Canon HV30 camera and it always worked fine. Makes me wonder where the problem lies.
    Intel dual core Q6600, Nvidia Quadro FX570, 4Gb Ram, Canon HV30 MC 3.5 Software 3 Media Composer MOJO DX /Unity 8tb [view my complete system specs]
    Greetings from Lisbon.
    Luis
  • Fri, Jun 12 2009 11:02 AM In reply to
    From the MC v3.1.3's read-me:
    "Bug Number: UDevC00108087. You might have received a “DIG_TOO_SHORT” error when performing a batch capture in a 720p 59.97 project. This has been fixed."
    Maybe you want to update your system?!
    Regards, g_f
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
