Latest post Mon, Jun 8 2009 4:45 PM by Vidiot Tech. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Jun 7 2009 4:45 PM
    • micromii
    • Joined on Sun, Jun 7 2009
    • Sweden
    • Posts 2
    • Points 30
    Dongle issues with Avid Xpress Pro
    Have been working with Xpress Pro for a few years now with no big problems. Though recently my Avid can’t seem to find the dongle. “No dongle was found. Please connect a valid dongle to this computer to ensure proper operation I’ve tried switching from different USB ports, tried the dongle manager and updating though even the manager explains that it does not find any dongle. Avid and the dongle have worked fine till now when this problem arose, and I’m totally lost. Software: Avid Xpress Pro 5.6.0
    OS: Windows XP SP3
    Help appreciated.
  • Sun, Jun 7 2009 5:20 PM In reply to
    • camoscato
    • Posts 6,077
    • Points 72,925
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Dongle issues with Avid Xpress Pro
    Take a look at this thread.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sun, Jun 7 2009 6:31 PM In reply to
    • micromii
    • Sweden
    • Posts 2
    • Points 30
    Thanks a bundle! I shall try!
  • Sun, Jun 7 2009 6:40 PM In reply to
    • camoscato
    • Posts 6,077
    • Points 72,925
      Moderator: Meridien
    You're welcome!  If the troubleshooting doesn't work, emailing Avid at the address in that link ought to help.  If not, come back to this thread and let us know and we'll get it worked out.
    good luck,
    Carl
  • Sun, Jun 7 2009 7:41 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Had this exact same problem a while back and it turned out the computer was not recognizing anything plugged into any USB port. Disconnecting the main power cable from the computer chassis, waiting 30 seconds, then reconnecting and powering up, the dongle was seen again.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Mon, Jun 8 2009 4:45 PM In reply to
    • Vidiot Tech
    • Joined on Thu, Apr 6 2006
    • South Carolina
    • Posts 120
    • Points 1,335
    Ah, yes! The old "Master Reset" trick! Does wonders, sometimes, when all else fails!
    System Specs: Dell M90, 4GB Ram (3GB Avid Enabled), nVidia FX 1500 w/ driver 8.4.2.9, MC 2.8, QT 7.2, External WD 750 GB eSata Drive [view my complete system specs]
    Steve Godsey, CLVS
    WARNING: Excessive consumption of alcohol leads to memory loss. Worse yet....it leads to memory loss.
