Greetings all,
I have posted this item on DS list earlier, but i'm hoping i'll find a reply from here as well.
I have the same problem with the new system we have. At times it works ok, but I have noticed the SICORE Engine issue from day one , the system hangs and a restart is always the solution.I ignored it because it was just a small project. Lately, just dragging or cutting a clip on the timeline triggers a system hang, What's more... i encountered that importing a .tga sequence stops the system from responding. I tried converting the file to avi and a quicktime file- same thing happens. Even deleting an audio track elicits the same restart sequence only to find that same problem once again. In addition to all these, upon playback the sytem generated an awfully loud noise that cannot be turned off even with the mute buttons.
I shut down the system for two days (weekend) and upon my return... i was able to delete the problem track and drag clips again onto the timeline, my worry is - this might just be a temporary reprieve. Does anybody know a solution to this? This has happened not just once. And the problem seem to get more complicated as it comes back.
Thank you in advance,
best regards,
Mario Dubai
Mario,
You are much better off contacting Avid Support via the phone hotline or the Ask a Question web form, and joining a V.I.E CAB file (check the Avid DS Support Console > Utilities Information for details) so they can inspect your system configuration.
This is not at all a common or a known issue with the HP xw8600...
Sylvain LabrosseAvid DS Product Champion | Video Customer SuccessAvid3510 St-Laurent BoulevardMontréal, QC H2X 2V2Canadasylvain.labrosse@avid.com We're Avid. Learn more at www.avid.com
Thanks Sylvain. I'll do that.
