Latest post Mon, Jun 8 2009 6:19 PM by mrmikster. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jun 5 2009 11:16 PM
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 58
    • Points 700
    Drag n' drop to the timeline...
    ...on DS10 doesn't work as 7.6 did.
    Fault or Feature?
    Previously (i.e. on v7.6) if you just wanted the video from a clip
    containing both video and audio to end up on the timeline
    you just "disabled" the source audio...
    and then it didn't matter if you used the Overwrite-button,
    the shortcut B or dragged and dropped the the selected
    piece to the timeline. No audio was ever put on any
    of the audiotracks.
    With version 10, using the Overwrite-button or the shortcut B
    gives the same behaviour, but dragging a clip to the timeline
    always gives you a new audio-clip on the timeline whether you
    want it or not.
    Even of you un-check the "Live-track" checkmark for every
    audiotrack on the timeline a "drag 'n drop" will create a
    new audio-track and put the audio on that.
    And this is not the way v7.6 behaves.
    So, fault or feature?
    //mike
  • Sun, Jun 7 2009 1:46 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 350
    • Points 3,920
    • Moderator: Avid DS
      Moderator: MetaFuze
    Re: Drag n' drop to the timeline...
    The Devs are aware of this change. It also annoys me.
    "There are no rules for the brave". Albert Einstein
  • Sun, Jun 7 2009 12:58 PM In reply to
    • marpan
    • Joined on Thu, May 14 2009
    • Dubai, UAE
    • Posts 9
    • Points 125
    I miss the feature on DS 4.0 where you just click on the tracks you want overwritten... and voila!
    You get what you need when you want it. No extras. :D
    I agree, this "feature" on DS10 needs to be rectified, I hope .
    HP xw8600 workstation* 30" monitor * 8GB RAM * 8TB of SAS storage * AJA rackmounted breakout box * Avid DS 10.1.1 software license * DS 10 RP * Media... [view my complete system specs]
  • Sun, Jun 7 2009 10:04 PM In reply to
    • M-Edit
    • Posts 58
    • Points 700
    Marpan, I'm not sure we mean the same thing,
    see picture below, but if we do, yeah it was
    immensely missed when it disappeared.
    And I think that function still was there in v5, because
    this screen-grab is from the v5 user guide.
    But the "track selection" in this picture only shows the
    option to change what's going to a video-track.
    Probably because this "Getting started"-clip only
    contained video.  Normally a clip containing both
    video and audio would show "v1" and "a1" on the
    "source side".
    And this might not seem as a big thing to groan about
    and it probably wouldn't be, if one kept using just 2 to 3
    layers or something. But when you end up with 15-20
    layers and have to race (Media Composer vertically wise)
    up and down the timeline just to hit the right destination
    track. Well, then it gets tiresome compared to when you
    just (as i v4, v5) choose the destination tracks in a
    couple of list boxes.
    And what was disappointing at the time, when the change
    to the Media Composer way of track selecting was made,
    was that there was no "backwards-compability-option" to
    use the old style of track selection. Like we don't care
    about the old users, they have to adapt, "Objection overruled".
    And this is one thing that seem to have stuck in my mind
    from the diifferent Discreet demo's of Flame, Flint or Smoke
    I've been to these last years. They seem to have cared
    for there old user-base and kept a lot of the ways of working
    in the old way while they also have introduced new ways
    of working.
    Finally, another thing I used to miss from that period was
    the LARGE trimview window that by default appeared on the
    left sceen. You could use the (large) trimview while still
    retaining the source/record view.
    Probably wouldn't make much sence nowadays when working
    with one monitor, but then it did, I think.
    //mike
  • Mon, Jun 8 2009 9:32 AM In reply to
    • marpan
    • Dubai, UAE
    • Posts 9
    • Points 125
    hello mike,
    Yes, that's the same track selector i miss from the earlier versions-  just click on the track(s) you want and it will be done, specifically vers 4 ( this is the only version i am used to before v10) so probably it will just be a matter of time before i get used to the new workarounds. So, from time to time i have to delete an unnecessary track created by the insert.
    I admit there's still lots of feature i have to master and smoothen my workflow. I am wondering if there are comprehensive tutorials and shortcuts lying about somewhere.
    best regards,
    Mario
    Dubai
  • Mon, Jun 8 2009 2:10 PM In reply to
    • slabross
    • Montreal
    • Posts 371
    • Points 3,700
      Moderator: Avid DS
    This Learning Collection website can still be usefull:
    http://aviddssupport2.avid.com/DS2/right/document/LearnColl/default.htm
    It's on the Avid DS Support Center, by the way...
    http://www.avid.com/ds/support
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Mon, Jun 8 2009 6:19 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 350
    • Points 3,920
      Moderator: MetaFuze
    So why not add it in? Go to "Layout - Edit Layout" and add it to the left side of your monitor. Right click and "set view - single instance views - trim".
    Easy right?
