hi i Aaron Montoya from Dart Costa Rica
I've problems when export an EDL because the DS change the name of the files in the timeline, i use the files from the Silicong imaging cameras in 2K, when i try the use this EDL in SpeedGrade doesn't match with the original clips.....
How is it changing the names? Can you give us an example of what the file names were before and after?
in the silicon imaging the names are DD/MM/YEAR/number of the clip like this
fe de agua_18_Mar_2009_02_48_01
but the EDL change this name for
fe_de_
and the EDL look
TITLE: V1FCM: NON-DROP FRAME*DS type=header major=1 minor=0*DS type=header frame-rate=24 fcm=non-drop-frame*DS type=header sort-order=none note-placement=above001 fe_de_ V C 00:00:00:00 00:01:45:15 00:00:00:00 00:01:45:15002 fe_d_1 V C 00:00:00:00 00:01:10:19 00:01:45:16 00:02:56:11003 fe_d_2 V C 00:00:00:00 00:01:12:08 00:02:56:12 00:04:08:20004 fe_d_3 V C 00:00:00:00 00:02:39:15 00:04:08:21 00:06:48:12005 fe_d_4 V C 00:00:00:00 00:01:08:03 00:06:48:13 00:07:56:16006 fe_d_5 V C 00:00:00:00 00:01:15:05 00:07:56:17 00:09:11:22007 fe_d_6 V C 00:00:00:00 00:00:59:00 00:09:11:23 00:10:10:23008 fe_d_7 V C 00:00:00:00 00:01:17:20 00:10:11:00 00:11:28:20009 fe_d_8 V C 00:00:00:00 00:01:15:16 00:11:28:21 00:12:44:13*DS type=source fe_d_1=fe\040de\040agua_18_Mar_2009_02_48_01*DS type=source fe_d_2=fe\040de\040agua_18_Mar_2009_02_43_24*DS type=source fe_d_3=fe\040de\040agua_18_Mar_2009_01_00_49*DS type=source fe_d_4=fe\040de\040agua_18_Mar_2009_00_51_19*DS type=source fe_d_5=fe\040de\040agua_18_Mar_2009_00_37_40*DS type=source fe_d_6=fe\040de\040agua_18_Mar_2009_00_30_52*DS type=source fe_d_7=fe\040de\040agua_18_Mar_2009_00_25_00*DS type=source fe_de_=fe\040de\040agua_18_Mar_2009_03_13_35*DS type=source fe_d_8=fe\040de\040agua_18_Mar_2009_00_02_36\040-\040001
the problem is this new name (fe\040de\040agua_18_Mar_2009_02_48_01) beacuse the Iridas don't find this clips....
So it appears that it is clipping the names according to the standard limitations of an EDL.
If that is the case, I'm not sure what the solution would be, other than some kind of 3rd party text/EDL manager. Unless I'm mistaken, EDL's will only display up to a max of 16 characters even with a RED EDL template (that DS doesn't have yet).
Am I missing something? Maybe someone else will chime in.
thanks
i will try to change the name from my first clip but one question, what happen with the METADATA?
