Latest post Fri, Jun 12 2009 4:40 PM by SteveBruns. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 4 2009 9:22 PM
    • SteveBruns
    • Joined on Thu, Jan 24 2008
    • Posts 5
    • Points 75
    SD to HD up rez
    what's the easiest way to reconform a project shot in HD that was cut in the DS in an SD project and the client wants an HD version of it?
  • Fri, Jun 5 2009 4:13 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    Re: SD to HD up rez
    Same framerate for both? If so, take the SD sequence, and save a copy. Create a new HD sequence with the appropriate scaling for the presets drop in the SD cut and recapture the media from the HD source. If different framerates, good luck.
    "There are no rules for the brave". Albert Einstein
  • Fri, Jun 5 2009 5:31 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: SD to HD up rez
    Since DS does not support SD at 23.97 or 24, I guess this HD material is in a compatible 59.94 frame rate, and so Michael suggestion will work.
    In the HD sequence, make sure to go under File > Sequence Preferences and set the Conversion Mode so the effects presets and media adjust to be proper scaling or the loaded SD sequence may end up wrong in the HD frame.  You might want to experiment a bit with very small sequences first hand, but you should figure out the proper recipe quickly.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Sun, Jun 7 2009 1:54 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
      Moderator: MetaFuze
    Re: SD to HD up rez
    I was thinking he may have used the decks downconvert for the SD source So the HD source could be 23.98 and the SD source 29.97.
    If this is the case, you can take your SD cut and load it into the EDL tool(save it somewhere you can find it), then process the 29.97 edl to 23.98 through the EDL Processor (look under tools). The difficulty lies in rebuilding any effects and composites. You would need to carefully save effects presets to a toolbar or bin from the SD cut for use in the HD cut.
  • Mon, Jun 8 2009 2:00 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: SD to HD up rez
    I guess if Steve does not reply then we'll never know...
    Sylvain Labrosse
    Avid
    Canada
  • Fri, Jun 12 2009 4:40 PM In reply to
    • SteveBruns
    • Posts 5
    • Points 75
    Re: SD to HD up rez
    frame rates matched so that was not an issue. Ended up importing SD sequence into HD timeline,
    purged media from sequence and recaptured at the proper size- programs were short so it went pretty quickly.
    thanks for the input always nice to have several ways of attacking client curveballs.
