Latest post Wed, Jun 3 2009 2:15 AM by ayakaonly. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jun 2 2009 4:15 PM
    • ayakaonly
    • Joined on Wed, May 13 2009
    • Posts 20
    • Points 270
    Putting a FX4600 in XW8400 possible ?
    Avid had said that in order to use the realtime proxy function, it will require a FX3700 / FX4600
    we are currently running the DS 10.1.1 with xw8400, so is it possible to put a FX4600 and has the realtime
    proxy working ?
    Thanks a lot
    Ayakaonly@MotionMotion
  • Tue, Jun 2 2009 7:10 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: Putting a FX4600 in XW8400 possible ?
    Engineering only has tested and qualified the NVidia 3500 in the HP xw8400 workstation.
    And even if the 3700/4600 would install and work, the GPU/CPU software acceleration would not be enabled because the application detects the hardware and activates the feature only for supported platform, and at this time it is the HP xw8600.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Wed, Jun 3 2009 12:29 AM In reply to
    Then, to clarify, the xw8400 isn't supported in a Xena-only (no Nitris DNA) configuration?
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Wed, Jun 3 2009 1:05 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    Correct, they don't have the processing power that the 8600 has. I had the Xena on the 8400 for a couple of months, it worked great as an assist station.
    "There are no rules for the brave". Albert Einstein
  • Wed, Jun 3 2009 1:33 AM In reply to
    OK then ...
  • Wed, Jun 3 2009 2:15 AM In reply to
    • ayakaonly
    • Posts 20
    • Points 270
    Thanks, then we have a strong reason to upgrade xw8600 Smile
