Latest post Mon, Jul 27 2009 8:51 PM by DIESELE. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Jun 2 2009 3:29 PM
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Posts 325
    • Points 3,805
    nVidia 169.47 on Vista 64
    Anyone out there seeing issues where Avid FX does not see the graphics card driver on Vista 64?
    I went to the nVidia site for the driver but they only list a 2000/xp version and a Vista 32 version of the driver.  Is there Vista 64 support for this driver or should the Vista 32 version work fine?
    Thanks for any and all insight.
  • Tue, Jun 2 2009 4:20 PM In reply to
    • ayakaonly
    • Joined on Wed, May 13 2009
    • Posts 20
    • Points 270
    Re: nVidia 169.47 on Vista 64
    For your informarion, I am running a newer driver on the Vista 64 since the 169.47 does not support the
    FX4800 on our new system. Media Composer seems to work as it should.
    We have been testing the new system for a few weeks and not yet having any issue.
  • Tue, Jun 2 2009 4:47 PM In reply to
    • mmullen
    • Posts 325
    • Points 3,805
    ayakaonly:
    What driver version is that?
  • Tue, Jun 2 2009 5:35 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,064
    • Points 27,490
    The 169.47 driver ships with MC 3.5.1 (you'll find it somewhere in the C:\Program Files (x86)\Avid\... directories (utilities?) Can't remember and I'm not in front of the Avid at the moment.
    Camera(s) Sony HDR-FX1, Canon HV20 | MC 4.0.2 | Vista 64 Ultimate SP2 | System: P5W-DH QUAD QX6700 (2.66GHz clocked to 3.2GHz), 8GB RAM (800MHz), 300Gb... [view my complete system specs]
    Steve
  • Tue, Jun 2 2009 5:45 PM In reply to
    C:\Program Files\Avid\Utilities\nVidia
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Tue, Jun 2 2009 5:54 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,064
    • Points 27,490
    Thanks... one mod:
    C:\Program Files (x86)\Avid\Utilities\nVidia
    (he asked about Vista 64)
    Steve
  • Tue, Jun 2 2009 6:09 PM In reply to
    • mmullen
    • Posts 325
    • Points 3,805
    hmm...
    I know where to find the driver that installs with the Avid.  What I was concerned about was I cannot find 169.47 on nVidia as qualified for Vista 64, just Vista 32, so I was just looking for some clarification on a Vista 64 version.
    The reason I ask is Avid FX does not see the graphics card driver even after the reinstall of the vid driver, mabe the customer is installign the incorrect one.
    Regarldess I'll give it another shot of installing from the Avid installed drive. Thanks for the insight guys.
  • Wed, Jun 3 2009 12:52 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,064
    • Points 27,490
    The reason I mentioned the location of the driver (in the utilities directory) is because I'm running Vista 64 with MC 3.5.1 and the FX 3700 and I'm successfully using the 169.47 drivers (x64 package) that shipped with MC.
    Find it here: C:\Program Files (x86)\Avid\Utilities\nVidia\Vista64
    You can't install a 32-bit driver on Vista 64.
    BTW - How do you know Avid FX does not see the graphics card driver (what does that even mean?). Do you mean that when you run an OpenGL test, Avid FX reports 'unsupported configuration'?
    Are you really talking about Avid FX or are you talking about Boris Continuum AVX (5.0.4)? BCC has a bug (recently discussed) that claims 'unsupported configuration' even on supported hardware/software (that's why I'm asking you this question).
    Steve
  • Wed, Jun 3 2009 3:47 AM In reply to
    • mmullen
    • Posts 325
    • Points 3,805
    Yes this is Avid FX, yes it is failing the Open GL test and in the open GL test the driver is blank.  In the past on Win XP you could solve this issue simply by reinstalling the driver...I've had the customer do this in this instance and the issue persists with the driver in the Avid folder.  Thats why I was asking if anyone knew if there was one from nVidia.  I wanted to have the customer download the driver from nVidia and try that one to test but all I can find is listed as Vista 32.
    I'm aware of all the other BCC issues. I just wanted to try to find another place to grab the driver from to try.
  • Wed, Jun 3 2009 4:11 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,064
    • Points 27,490
    I go to the nVidia driver download page, select the 'beta and archived drivers' link in the lower half of the page. From there I specify the search criteria Quadro, FX series, FX 1700 (in your case) and then I specify Windows Vista 64 and perform the search. It actually comes up with two April 3, 2008 entries for 169.47 (and these are 64-bit drivers).
    Is this the approach you took to finding these?
    Steve
  • Wed, Jun 3 2009 4:20 AM In reply to
    • mmullen
    • Posts 325
    • Points 3,805
    No, but now I know how to find it.  Thanks
  • Thu, Jul 16 2009 8:43 PM In reply to
    • ronn
    • San Diego
    • Posts 401
    • Points 4,910
    With a new Dell Studio XPS running Vista Ultimate 64:
    When I try installing 169.47 from the utilities/nvidia/vista64 folder - I get the error message:
    The NVIDIA Setup program could not locate any drivers that are compatible with your hardware. Setup will now exit.
    At this point I have not installed MC on this (new today) computer. I replaced the ATI Radeon HD with an FX1300 and installed the Nvidia 96.85 driver from their website, and it works (although I have not tried with Avid yet).
    Anyone?
    Media Composer 4.0.2, ASUS P6T/i7-920/12GB, Dell Studio XPS, i7-920/6GB, Windows Vista Ultimate 64 bit, HPxw8200 w/3GB/MC3.1.2/XP, FX1700, FX1300, FX570... [view my complete system specs]
    Ronn Kilby
    The Studio at Kilby Pond
    Valley Center, California
    www.kilbypond.com
    Where work - is a pleasure.
  • Mon, Jul 27 2009 7:09 PM In reply to
    • cadaly
    • Joined on Mon, Jul 27 2009
    • Posts 1
    • Points 15
    I'm replying here because I have a different, but equally annoying problem.  I have a BRAND NEW recommended Vista Business 64 bit / NVIDIA QUADRO 3700M system.  When I start media composer, I receive the prompt to install an older version of the display driver:  169.47.  Indeed, this ships with MC.  However, when I try to install it -- EVEN AFTER UNINSTALLING USING CONTROL PANEL -- it says that since it has a 32 bit uninstaller, I can't do a thing.  Can't get the one from NVIDIA to install.  So I uninstalled the whole thing and let windows find what it wanted.  Probably 190? Dunno.  Seems to be starting trouble-free, though I haven't *done* anything, though I have all these old drivers populating my computer now.
  • Mon, Jul 27 2009 8:51 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 326
    • Points 3,985
    Hmm - not much help, but I too am in the middle of a sys rebuild from XP to Vista 64.  I installed 169.47 and the screen went black!!!  I tried 'easing' out of the system to re-start and I do have two differnt displays now, rather than clones.  Its not right though, so will persevere to get it as good as XP!
    My biggest issue is that I cant install Avid 3.1.3 as the downloads always seem incomplete or corrupt - as posted elsewhere.  Running Avid will tell me if NVidia driver is OK...
    D
    Panasonic HPX301 P2 Camcarder (sic!), MC 4.0.3, Vista 64 SP2, Asus P5K-E Mobo, Q6600 Dual Quad Core @ 2.4Ghz (3.0 Ghz if I'm up against it!), 8Gb 800Mhz RAM Dual channel, C: Raptor (can you hear it?!) Media: 4 x 500Gb SATA Stripe O pairs, P2 archive E-Sata WD x 4, Quadro FX 1500 GFX, Soundblaster Audigy, Mojo SDi.  Sony PVM CRT.  Approved Avid HP 8240 Notebook.
    VIDEO PRODUCTION SOUTH WALES CRACKING PRODUCTIONS
