Latest post Sat, Jul 25 2009 5:55 PM by slydvd. 11 replies.
Page 1 of 1 (12 items)
  • Tue, May 26 2009 7:23 PM
    anyone using DX hardware with single quad or dual 2.26GHZ Nehalem?
    Hi Everyone
    I realise that Avid is only supporting the top two new 'Nehalem' MacPros but is there anyone on here who is successfully using v3.x MC with DX hardware running on the cheaper Nehalem single quad or the cheapest (2.26Ghz) dual quad?
    Those top two MacPros are just crazy expensive!
    Any help appreciated!
    3xMacPro dual 3.0Ghz with MC + Mojo SDi all with 8GB RAM; 1xMC Soft on MacBook Pro; 1xMacPro running FCStudio and AJA Kona LHe; all the scopes, legalisers... [view my complete system specs]
  • Wed, May 27 2009 2:02 AM In reply to
    • swatchpost
    • Joined on Fri, Apr 4 2008
    • Austin, TX
    • Posts 83
    • Points 1,020
    Re: anyone using DX hardware with single quad or dual 2.26GHZ Nehalem?
    It is absolutely worth every penny to get the top of the line Mac Pro.  I just bit the bullet last week and my productivity has quadrupled.  It is worth absolutely every penny, and you might as well upgrade to the 2.93 because that's the only one that has hyper-threading—super super useful when you've got a lot of encoding that needs to be done.  I can export an entire ProRes QT of a 1:40min feature film in an hour and it takes 21mins to encode that QT into an MPEG2 using Compressor.  Seriously substantial difference between the others.
    Just my .02
    Avid Mojo DX w/MC v3.5.4, 2x2.93GHz 8Core Mac Pro, 16GB RAM, 10.5.7, QT v7.6.4 ; Avid MC v3.5.4, 2x3.06GHz MacBook Pro, 4GB RAM, 10.5.7, QT v7.6.4 [view my complete system specs]
  • Wed, May 27 2009 11:52 AM In reply to
    Thanks.  Good to know. My profile specs aren't up-to-date.  At the moment we have two Harpertown 3.0Ghz dual quads, which are supported just fine on the DX hardware.  We need to add a third suite here in the next few days, so it'll have to be a second-hand Harpertown or one of the new models.  The price difference is absolutely huge, so I think we'll just run the DX on one of our existing systems and go second-hand.  Shame.  £2.5k for the previous Avid-supported Macs just turned into £4k.  Oh dear.
  • Wed, May 27 2009 4:38 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,836
    • Points 201,210
    Post, Marianna was telling me that there is definitely a problem running the software on the Single Nahelems. So, I'd definitely stay away from those.
  • Wed, May 27 2009 4:56 PM In reply to
    Okay. Thanks.
  • Wed, May 27 2009 5:20 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    I just ordered the Dual 2.26. Will be running with Mojo and 3.5, will see how it works and let you know.
    Huh?
    Dual 2 GHZ MAC.6 gig ram,3 gig hard drives, Avid w/ MOJO, FCP, Motion MBP Intel core 2 Duo,2.6 GHZ 4 gig ram, 17 inch Matte screen, Avid w/Mojo, &... [view my complete system specs]
    Filed under: , ,
  • Wed, May 27 2009 11:56 PM In reply to
    Thanks!  Mojo SDI or Mojo DX?
  • Fri, Jun 19 2009 12:30 AM In reply to
    • wiezowiec
    • Joined on Thu, Jun 18 2009
    • Posts 2
    • Points 30
    Hello wsimonett
    Did you check Mojo with dual 2.26 Xeon?
    Thanks for the answer.
  • Thu, Jul 23 2009 3:46 PM In reply to
    • pierreh
    • Paris, London
    • Posts 653
    • Points 8,010
    I'm about to get a new machine, and this is exactly the question I have: does anyone work with a 2xQuad 2.26 Nehalem here? Is that fine? Or should we get the next one up in the Mac Pro lineup?
    Edited for more info:
    The machine will be used mainly for offline of feature film, cut in DNxHD36 or SD DVCAM. No fx, nothing really processor intensive.
    Personal system: MacBookPro 2.5Ghz, 4Gig Mem, Mojo - Work system: MacPro Nehalem, 3 monitors, internal Raid setup [view my complete system specs]
  • Thu, Jul 23 2009 4:14 PM In reply to
    • wiezowiec
    • Posts 2
    • Points 30
    I have two of them and it works.
  • Thu, Jul 23 2009 8:32 PM In reply to
    • pierreh
    • Paris, London
    • Posts 653
    • Points 8,010
    wiezowiec:
    It works or it rocks? Wink
  • Sat, Jul 25 2009 5:55 PM In reply to
    • slydvd
    • Austria
    • Posts 36
    • Points 530
    Hi!
    I just built exact this System
    Dual 2,26 Nehalem, 12GB (6x2GB!!!) 2x 500GB Raid0 as System + external 1TB WD as TimeMachine
    2x1TB Raid0 with external WD 2TB Backup
    Slot 1 G120 GeForce
    Slot 2 Decklink HD Extreme Blackmagic
    Slot 3 Highpoint SATA Raid Card with 4x 750 SATA HDDs in RAID 5
    Slot 4 Avid Xpress MOJODX Card
    OSX 10.5.7, MC 3.5.4 and works Rock Solid with MojoDX (Still from time to time Busthread Errors (2x/Week)
    But I can Use the Decklink SDI to Analogue throughoutput to get an extra Analogue output from MojoDX !!!
    regards
    Sly
    2xQC 2,26GHZ MACPro Nehalem ,12 GigRAM, NVidea 120GT,1TB System, 4TB SATA Raid ,2x24" FullHD DellScreens,MC3.5.1 ,FXFactory,FinalCutStudio,DecklinkHD... [view my complete system specs]
    SeeYaa Sly in MMIX ----------------------------------- HD is the only resolution in LIFE MC AdrenalineHD Editor
