Latest post Sat, May 23 2009 11:10 AM by Bloersch. 1 replies.
Page 1 of 1 (2 items)
  • Fri, May 22 2009 3:00 PM
    • SPROCKETS
    • Joined on Fri, Nov 18 2005
    • Posts 4
    • Points 50
    Full Screen Jitter on Mac LCD Monitor
    Normal 0 false false false <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} p.MsoPlainText, li.MsoPlainText, div.MsoPlainText {margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:Arial; mso-fareast-font-family:"Times New Roman"; color:black;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    Hi All
    I'm currently running the following:
    Working on Mac pro (2009)
    Running on OS 10.5.6
    8gb Ram
    Media Composer 3.5.1
    Running Two Apple 24 inch LCD Displays
    Avid 25p PAL Project
    Running DV25 420
    16x9 Full Height Anamorphic
    Whichever monitor I assign as a primary monitor for running full screen display then it jitters and stutters, but not on the other monitor. I have tried fiddling with mac settings and Avid Full Screen Settings but monitor 1 seems fine and not monitor 2, but when when I swap the primary monitor settings (in avid  or mac settings),  monitor 2 is fine but not monitor 1.
    This is annoying as I like to have the full screen on monitor 1 primary (left) so I can run the timeline/ source record monitors from the right, monitor 2.
    Any thoughts?
    Paul
  • Sat, May 23 2009 11:10 AM In reply to
    • Bloersch
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 164
    • Points 1,975
    Re: Full Screen Jitter on Mac LCD Monitor
    In console try "fsp locked" and see if that helps.
    MC 3.1.3, OSX 10.5.5, MacBook Pro 17'', 2.33 GHZ Inter Core 2, Mojo SDI, e-Sata HDD [view my complete system specs]
