Latest post Mon, Oct 12 2009 2:09 AM by drbgaijin. 12 replies.
Page 1 of 1 (13 items)
  • Fri, May 22 2009 1:09 AM
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    4 Simple Steps from HD to an SD DVD
    Not everyone wants to author a fully featured DVD with chapter points. menues. subtitles etc.
    Sometimes all that is required is a quick output of a sequence in MC to a DVD with nothing added.
    Here is one workflow which is simple and requires only 4 easy steps.
    Good luck!
    Regards,
    Douglas
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Sat, May 23 2009 11:38 AM In reply to
    • Inbetween
    • Breda The Netherlands
    • Posts 30
    • Points 410
    Re: 4 Simple Steps from HD to an SD DVD
    Sorry, this tutorial seems not to work on my Imac 24. Nothing shows up.
    Dell WS 690 dualcore 2,66, 4 GB RAM, 500 GB SATA raid 0. 2 x 750GB Nvidia 570 . Certified firewire PCI card. MOJO. MC 3.5.1 [view my complete system specs]
  • Sat, May 23 2009 11:50 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    Inbetween:
    Raoul,
    I am sorry, but I have no knowledge of Macintosh systems at all.
    I know that the Tutorial files are in Flash - flv format.
    Adam Kranitz of Avid can almost certainly give you advice on this.
    But the USA is having a long holiday weekend just now and probably won't see your post until Tuesday.
    In the meantime I suggest you post something on the MC -  Mac Forum.
    Give them a link to the Tutorial and ask someone to try it out for you.
    Maybe they can view it and advise you how to proceed.
    Sorry I can't be more helpfull.
    Regards,
    Douglas
  • Sat, May 23 2009 3:37 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,061
    • Points 27,445
    Hi Douglas - nice quick workflow - Thanks. One question:
    Why do you select Avid DV Codec and RGB - the HD footage is 701 - does Avid DVD require this step?
    Steve
    Camera(s) Sony HDR-FX1, Canon HV20 | MC 4.0.2 | Vista 64 Ultimate SP2 | System: P5W-DH QUAD QX6700 (2.66GHz clocked to 3.2GHz), 8GB RAM (800MHz), 300Gb... [view my complete system specs]
    Steve
  • Sat, May 23 2009 4:05 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    I have no idea, Steve! Confused
    Seriously, though, I tried some experiments with the settings
    See
    Link 109  From MC to AvidDVD - A look at the Settings
    The RGB gave me more vibrant colours, The Avid DV codec was by force of habit. It doesn:t actually seem to affect it one way or the other...... in the cases I described.
    Good luck,
    Douglas
  • Sat, May 23 2009 4:36 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,061
    • Points 27,445
    Thanks, Douglas. I'll experiment with this myself to see the difference. I'd also like to see the difference when using an external encoder like TmpGEnc - sometimes I've noticed the videos looking washed-out and have suspected this was due to a mismatch between color schemes.
    Steve
    Steve
  • Sun, Jun 14 2009 8:42 PM In reply to
    • tinam
    • Joined on Sun, Jun 14 2009
    • Posts 1
    • Points 5
    Are you using Safari as your browser? It only works on my mac with Firefox.
    Tinam
  • Sat, Jun 20 2009 10:43 PM In reply to
    • Inbetween
    • Posts 30
    • Points 410
    I watched it on a PC. It worked fine.
    Thx
    Raoul
  • Thu, Aug 20 2009 10:54 PM In reply to
    • DonR
    • Irving, Mexas
    • Posts 158
    • Points 2,190
    Very imperssive!
    Once my file is exported from MC 3.5.4, it goes through a different MPEG encoder and burner.
    No doubt you get excellent quality since you begin with HD. The head of OMNI who markets Cinema Craft advised me a couple of weeks ago the HD to SD quality is really excellent.
    Thank you for sharing your work with us.
    Don R.
    SuperMicro Superworkstation 7045A-T Computer Hardware: 1-Supermicro Sys-7045A-TB 4U Xeon 1333FSB FB-DIMM 6XSATA Motherboard X7DAE 2-Intel... [view my complete system specs]
  • Mon, Oct 12 2009 12:41 AM In reply to
    • helidon
    • Joined on Thu, Oct 8 2009
    • Posts 10
    • Points 90
    In order to make a QT Reference, you have tou change the project format to 25i PAL (for europe), even if the footage is 1080i50, otherwise you can't make it.
    Is this correct, or is it some kind of bug? I had the same problem on 3.0.2 and 3.5.4 of AMC on PC.
    sometimes, i have some drops in frames which a long dissolve effect takes place, even after the video & audio mixdown procedure. but i solved the problem today. just edited the dissolve effect from 30 frames, to 32 frames, and partially replaced the new video mixdown!
    always do some test before long time procedures like this one...
  • Mon, Oct 12 2009 12:49 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    helidon:
    Hello Helidon, and welcome to the Forum.
    As I am working with NTSC I cannot really give you an answer to that question.
    I would suggest you post this question over on the regular Media Composer - PC forum.
    There are more people looking over there, so you should get an answer I think.
    Good luck,
    Douglas
  • Mon, Oct 12 2009 12:58 AM In reply to
    • helidon
    • Posts 10
    • Points 90
    Hello hello!! Big Smile
    As a new member, i'd appreciate any help with some kind of link to an already existing topic.
    i've been a little offtopic, i'm sorry.
    btw, nice community!
  • Mon, Oct 12 2009 2:09 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    Helidon,
    I guess you are meeting the problem with "Long GOPs"
    I have a tutorial where this is described.
    Maybe you can get help from it:
    Link07    HDV and the Long GOP" error - problem and solution
    Good Luck,
    Douglas
