Latest post Thu, Sep 11 2008 4:41 PM by Randall L Rike. 132 replies.
Page 2 of 9 (133 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Sat, Feb 25 2006 6:26 PM In reply to
    • adam5000
    • Posts 199
    • Points 2,810
    Re: Another Avid Media Database FREE Tool - MDV
    Nice.  Great tool.  I was wondering if there is any way to make the "Name in Bin" column display the names without having to click on each specific file.  Or maybe there could be a way to highlight/select a bunch or all files and then have the "Name in Bin" column update.  It seems that now you have to click on each and every file to get them to show up in the "Name in Bin" column.  Works greeeeat otherwise.
    Great job.  This should be in 6.0!!!
    -adam5000
    HP xw8200Dual 3.2 Processors, 2 GiG of RAM, nVidia fx3400, ADS Pyro Firewire Card, Audigy Sound Card, EXT firewire Hard Drives, 2 x NEC LCD monitors, Mojo [view my complete system specs]
  • Sat, Feb 25 2006 9:44 PM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 76
    • Points 1,120
    scanning all files automaticaly is !VERY! slow process!!
    especially if you have more than 10000 files and they are stored on UNITY or LANSHARE server.
    i'll try to speed up/optimize it in future.
    but in current build you can highlight/select a bunch or all files in filelist window
    and then press F2 button.
    MC Adrenaline HD 2.6.6; HP XW8200; 2gb RAM; 5Tb UltraStor RAID; MC 2.6.x soft+mojoSDI; HP XW 8200;2gb RAM; 7Tb UltraStor RAID; MC 2.6.x soft+mojoSDI;... [view my complete system specs]
    DJFio[DB]
  • Sat, Mar 11 2006 8:59 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 76
    • Points 1,120
    11 mar 2006
    Updated.
    *Speeded up file scanning
    *Added option to scan any media folder (with *.omf *.aif and *.wav files) without using databases(*.pmr) (the way like Media mover does)
    DJFio[DB]
  • Mon, Mar 20 2006 2:56 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 76
    • Points 1,120
    build 20 mar 2006
    added ability to scan avid bins.
    now you can diagnose your bin and get all referenced media files and projects.
    or you can drag mediafiles and sequences into your bin(with AVID), analyse it, and copy/move all your referenced mediafiles anywhere
    DJFio[DB]
  • Mon, Mar 20 2006 3:05 PM In reply to
    Wow. Thanx for the program and the updates! It is a great tool.
  • Mon, Mar 20 2006 4:17 PM In reply to
    • conleec
    • Los Angeles
    • Posts 521
    • Points 6,830
    If I understand this correctly, this means I can create a bin with just my finished sequence in it and then use this tool to copy only the referenced media. Is this correct? If so, that's awesome.
    (The tool's already awesome, by the way. Thanks!)
    Chris
    xw8200, Dual 3.4Ghz Xeons, 4Gb RAM, vVidia FX1300, Adrenaline HD, MC 3.0, QT 7.4.5 [view my complete system specs]
  • Mon, Mar 20 2006 4:38 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    yeah great tool indeed... good work!!!
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Mon, Mar 20 2006 5:05 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 76
    • Points 1,120
     conleec wrote:
    If I understand this correctly, this means I can create a bin with just my finished sequence in it and then use this tool to copy only the referenced media. .............
    theoretically yes, but this way MDV was not tested..............
    so, if you do some tests, it would be great!
    DJFio[DB]
  • Mon, Mar 20 2006 11:38 PM In reply to
    • miky
    • Posts 421
    • Points 5,400
    This guy is too fast, I haven't had the time to test the 11/03 version yet.
    Thanx Mr. for an essential tool.
    M.C.
    M.C.
  • Mon, Mar 20 2006 11:59 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 76
    • Points 1,120
    Big Smile [:D]
    DJFio[DB]
  • Wed, Mar 22 2006 10:06 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 76
    • Points 1,120
    another major update!
    ------ 23 mar 2006 ---------
    feature added!
    now you can right click in project list window and select "Store..."
    (or select some files in file list and press F4)
    then select target folder.....
    then select "Store relative Paths" and "Add drive letter to relative path"
    or you can select an option "store MXF anf OMF separately" -
    the subfolders named "OMFI mediafiles" and "AVID mediafiles" will be created for you.
    and all the media will be copied there.
    also you can select an option to move your media instead of copy.
    NOTE: there is no difference between "Store relative Paths" and "store MXF anf OMF separately" on AVID stations with local storage, but on unity and lanshare with "Store relative Paths" checked all user workspaces will be stored correctly.
    DJFio[DB]
  • Wed, Mar 22 2006 10:37 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 958
    • Points 11,630
    • Moderator: Avid Symphony Nitris
    Avid, hire this guy Big Smile [:D]
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Wed, Mar 22 2006 10:45 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 76
    • Points 1,120
    Big Smile [:D] Re: Another Avid Media Database FREE Tool - MDV
    Wink [;)]
    Tongue Tied [:S]
    p.s. If you already downloaded this tool, please do it again. There was a serious bug.....
    (MDV crashes sometimes)
    DJFio[DB]
  • Thu, Mar 23 2006 12:25 AM In reply to
    Why do you rock so much?
    :D
  • Thu, Mar 23 2006 3:41 AM In reply to
    • transpics
    • Tennessee
    • Posts 437
    • Points 5,275
    Yes, please. Put him in charge of fixing things and making stuff work.
    P4, 2.80 GHz, 2 GB RAM, 160 GB System Drive, 228 GB Video, 2 x 100 GB Firedock drives, 1 x 300 GB additional media drive, 160 GB WD external Firewire drive... [view my complete system specs]
    Manny "Lock it. Episode 5 airs tomorrow." "But you gave me Episode 4. This is 4." "<blink>Make some coffee."
