Latest post Thu, May 21 2009 6:05 PM by outpostbc. 7 replies.
  • Thu, May 21 2009 4:24 AM
    • the_don
    • Joined on Fri, May 8 2009
    • NY, NY
    • Posts 8
    • Points 110
    Red lines, not on TC
    The effects manual says that if Avid dropped frames on playback (in my case, failed export to QT Reference) it will display red lines on the TC track. Well I've had a few situations where the red line appears on a portion of one of the video tracks. What does this mean? Same thing? Different?
    HP xw8200. 3gb ram, dual 3.4ghz processors. 160gb internal sata HDD. Nvidia Quatro 1400. Win XP SP2, AMC 2.2.15 Adrenaline, Unity 3.5. [view my complete system specs]
  • Thu, May 21 2009 4:58 AM In reply to
    Re: Red lines, not on TC
    If you have Dupe Detection turned on, that may appear as a red line on a video track.  Dupe Detection only applies to V1.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Thu, May 21 2009 5:56 AM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    If there's a partially-rendered effect on the clip, the red line could be marking the portion of the effect that is unrendered.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Thu, May 21 2009 12:28 PM In reply to
    Yup, you might want to check out this thread:
    http://community.avid.com/forums/p/69511/388794.aspx#388794
    HTH.
    P4 3.0. 4 Gig RAM, CAS 2.0. 3Gig patch. Intel 865PERL mobo. Two WD 7,200 IDE drives. SIIG SATA II-150 PCI RAID card w/ 2 WD Raptor 10,000 SATA drives as... [view my complete system specs]
  • Thu, May 21 2009 3:19 PM In reply to
    • the_don
    • NY, NY
    • Posts 8
    • Points 110
    camoscato:
    Thats definitely it. It's not on V1 and when I change the render range in the timeline fast menu, the lines go away. Rendering in/out around the lines made my export go smooth as silk. Thanks for the help! One more question: Does the Video quality button in the timeline effect render time/quality? Or is it simply for playback?
  • Thu, May 21 2009 3:30 PM In reply to
    It only affects playback. Render quality is affected by the Render tab of Media Creation settings, which you choose in the Project Window.
  • Thu, May 21 2009 4:57 PM In reply to
    • the_don
    • NY, NY
    • Posts 8
    • Points 110
    BobbyMurcerFan:
    Got it. So if i'm working offline in 20:1 MXF, and making a quicktime ref, the most efficient settings would also be 20:1, correct? If thats the case, selecting the "same as source" selection should keep me at the most efficient settings?
  • Thu, May 21 2009 6:05 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 280
    • Points 3,450
    the_don:
    A quickime ref doesn't do any recompression, it points to the original media. That being said, it does need to render effects for the Ref file and those wil be determined by your media creation settings.
    Media Composer Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Symphony Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Unity MediaNet 5.1.3 [view my complete system specs]
