Latest post Wed, May 20 2009 5:11 PM by the_don. 2 replies.
  • Tue, May 19 2009 2:00 AM
    • the_don
    • Joined on Fri, May 8 2009
    • NY, NY
    • Posts 8
    • Points 110
    Exception: FILE_OTHER, filename ...
    Any sequence I play will eventually crash, usually within 10 minutes. I get the error "Exception: FILE_OTHER, Filename: G:\OMFI MediaFiles\Edit7\xxxxxxx.mxf". If I hit OK and try to play again, I immediately get a similar message, except with an aif extension. It will do this until I reboot the computer. Here is what my console spits out during and after the event. (HP xw8200, MC Adrenaline 2.2.15, Unity 3.5.)
    Dongle ID: xxxxxxxxxxxx
    System ID: xxxxxxxxxxxxxx
    Avid Media Composer Adrenaline HD
        Avid DVD by Sonic
    In Init ARO Cmds
    MSMRescan() took:     0.875000s
    The default render wait time is 50
    Audio underrun detected and suppressed - total samples slipped 46447.
    Audio underrun detected and suppressed - total samples slipped 54455.
    Audio underrun detected and suppressed - total samples slipped 91291.
    Audio underrun detected and suppressed - total samples slipped 144144.
    Audio underrun detected and suppressed - total samples slipped 145746.
    Audio underrun detected and suppressed - total samples slipped 238639.
    Audio underrun detected and suppressed - total samples slipped 339540.
    Audio underrun detected and suppressed - total samples slipped 374776.
    Audio underrun detected and suppressed - total samples slipped 8008.
    Audio underrun detected and suppressed - total samples slipped 11211.
    Audio underrun detected and suppressed - total samples slipped 43243.
    Audio underrun detected and suppressed - total samples slipped 46446.
    Audio underrun detected and suppressed - total samples slipped 126526.
    Audio underrun detected and suppressed - total samples slipped 224223.
    Audio underrun detected and suppressed - total samples slipped 225825.
    Audio underrun detected and suppressed - total samples slipped 261060.
    Exception:
    @ Mon May 18 20:06:22 2009
    * Exception: FILE_OTHER, filename:G:\Avid MediaFiles\MXF\EDIT14.1\A041505SV01.49E7EC03.7BCE60.mxf
    * Exception: SYS_ERROR, status:1127, msg:While accessing the hard disk, a disk operation failed even after retries.
    Exception:
    @ Mon May 18 20:07:03 2009
    * Exception: FILE_OTHER, filename:G:\OMFI MediaFiles\EDIT16\701-2T17.WA03.49E8149E81B1C.aif
    Exception:
    @ Mon May 18 20:12:32 2009
    * Exception: FILE_OTHER, filename:G:\OMFI MediaFiles\EDIT16\701-2T21.WA04.49E8149E81B37.aif
    Exception:
    @ Mon May 18 20:12:35 2009
    * Exception: FILE_OTHER, filename:G:\OMFI MediaFiles\EDIT16\701-2T19.WA04.49E8149E81B2F.aif
    Exception:
    @ Mon May 18 20:12:38 2009
    * Exception: FILE_OTHER, filename:G:\OMFI MediaFiles\EDIT16\701-2T19.WA03.49E8149E81B2F.aif
    Exception:
    @ Mon May 18 20:12:40 2009
    * Exception: FILE_OTHER, filename:G:\OMFI MediaFiles\EDIT16\701-2T21.WA03.49E8149E81B37.aif
    Exception:
    @ Mon May 18 20:12:43 2009
    * Exception: FILE_OTHER, filename:G:\OMFI MediaFiles\EDIT16\701-2T23.WA03.49E8149E81B40.aif
    The Exception error does not come up until all the audio underrun errors have occured, which takes less than a minute.
    We put the editor who was having the problem in another edit suite and she has been working on the project for hours with no issues. I've also opend a few different projects from different shows and different unity locations and I will get this error no matter what.
    I've trashed the user setting, made a new user, imported a problematic bin into a new project, created a local project, and none of that has worked. It's almost like this tower is losing connection to Unity, but I get no errors from my ATTO card and the drives never unmount. I can even explore them via the desktop at any time during or after the errors.
    Any wisdom would be greatly appreciated.
    -Dan
    HP xw8200. 3gb ram, dual 3.4ghz processors. 160gb internal sata HDD. Nvidia Quatro 1400. Win XP SP2, AMC 2.2.15 Adrenaline, Unity 3.5. [view my complete system specs]
  • Tue, May 19 2009 3:34 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: Exception: FILE_OTHER, filename ...
    Dan,
    This is a weird one.....  Normally underruns on playback are related to low bandwidth data connections etc... or a drive related issues - speed can play a factor.
    I suggest you call in to support and have one of the tech's work this with you.  Could be many things...... and you might need a unity tech on this one.
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Wed, May 20 2009 5:11 PM In reply to
    • the_don
    • NY, NY
    • Posts 8
    • Points 110
    Marianna:
    Faulty ATTO card was the issue. Swapped it and haven't had a so much as a hiccup. Thanks for the lead!
    -Dan
