Latest post Fri, May 15 2009 4:06 PM by UdSSR. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Fri, May 15 2009 3:34 PM In reply to
    • grayboy
    • Halifax, West Yorkshire
    • Posts 451
    • Points 5,840
    Re: Precomputes can't be loaded into monitors error
    the wayyou have your time line set up you arent monitoring V2, which is where your PIP are.  click on the box on the right of V2 and you will see your PIP.
    MC ver3. HPxw8400 Intel R Xeon quad core 5150@2.66Ghz. 3Gb ram. Xp Pro 4.6 Service Pack 2Pentium 2.8 GHZ2GB Ram Matrox Millenium G550 dual display80GB... [view my complete system specs]
  • Fri, May 15 2009 3:42 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    UdSSR:
    it is just to illustrate that there only one column of V1,A1 and A2 instead of
    V1 V1
    A1 A1
    A2 A2
    All that means is that a source clip is not loaded in the source monitor.
    Check and make sure you monitor icon is on the highest video layer.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Fri, May 15 2009 3:51 PM In reply to
    • UdSSR
    • Joined on Thu, Apr 23 2009
    • Soviet Union
    • Posts 64
    • Points 945
    grayboy:
    That's it! Now I can see those PIPs. Also I have fixed the timeline (just accidentally) by rightclicking on V1 and choose Match Frame Track and two columns are back! Thank you guys!
    Alex,
    KGB
    Senior ticket-collector
  • Fri, May 15 2009 3:52 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    UdSSR:
    That's not the point, it is just to illustrate that there only one column of V1,A1 and A2 instead of
    V1 V1
    A1 A1
    A2 A2
    To give you a visual explanation of what Larry said about the source monitor, maybe this will help.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Fri, May 15 2009 3:58 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    The match frame function will load any standard clip that you're parked on in the timeline into the source monitor and will automatically place a mark in on the source at that exact point. However, as you've discovered, match framing will not work with pre-computes. That's where my CTRL + ALT +c workaround comes in.
    Since it seems you are relatively new to Media Composer, here are links to two threads of free tutorials created by one of our other moderators, Douglas Bruce. I think you'll find them well worth the time.
    Link 1
    Link 2
  • Fri, May 15 2009 4:06 PM In reply to
    • UdSSR
    • Soviet Union
    • Posts 64
    • Points 945
    drbgaijin:
    Hey Doug, thanks and I  am certainly watching  all your  lessons, it is great! I just finally got what I wanted from Larry and grayboy posts...  Waiting for your new tutorials Geeked
    Alex,
    KGB
