Latest post Tue, May 19 2009 3:47 PM by wsimonett. 15 replies.
  • Tue, May 12 2009 5:15 PM
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Avid MojoDX and MacBook Pro
    Is anyone using the MojoDX with MBP? Considering one for my MBP and just wondering how it performs?
    Is HD possible with it. The specs seem to indicated HD will not work with MBP using the MojoDX.
    Any feedback is welcomed.
    Thanks in Advance!
    Bill
    Dual 2 GHZ MAC.6 gig ram,3 gig hard drives, Avid w/ MOJO, FCP, Motion MBP Intel core 2 Duo,2.6 GHZ 4 gig ram, 17 inch Matte screen, Avid w/Mojo, &... [view my complete system specs]
  • Tue, May 12 2009 10:11 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 703
    • Points 8,435
    Re: Avid MojoDX and MacBook Pro
    Hi... I'm editing HD on a MacBook Pro without a Mojo of any sort.  Just using my cinema display to monitor, which I know isn't perfect, but everything is working fine.  I use external SATA drives.  Import up to DNxHD 220 and edit with no hiccups.
    Malcolm
    MBP 2.5GHz, 4GB RAM, OSX 10.5.4; Media Composer v.3 [view my complete system specs]
  • Wed, May 13 2009 4:44 PM In reply to
    I'm assuming that you would use one of the magma chassis for the card. I have to say, I'd be surprised it if it worked well. Also, capturing DNX needs an 8 core mac so that little MBP would be huffin' and puffin'.
    I say MC Soft and or an SDI mojo and let someone at a post house capture your footage into a compressed HD format. Use that card slot for an eSata card for media drives.
    just my .02
    Don't trust the internet...
  • Wed, May 13 2009 4:49 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    mhamilton:
    Malcolm
    How do you got to tape with this or do you just author on DVD?
    Bill
  • Wed, May 13 2009 4:53 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    hidefcowboy:
    just my .02
    Oh-I just assumed it came with a notebook card.
    It dosen't come with a notebook card?
    Filed under: , ,
  • Wed, May 13 2009 4:54 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 703
    • Points 8,435
    Yes, I just output to uncompressed QT, and have a place that specializes in these things output to whatever the client wants.
    And... what am I missing... my MBP doesn't seem to huff and puff at all (DNxHD 220 notwithstanding).  2-cores only, as far as i know.
    I'm probably not doing something the rest of you are.
    Malcolm
  • Fri, May 15 2009 9:41 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Thanks Hamilton, that helps.
    But I'm wondering if anyone from Avid can confirm that the Mojo DX will not work with a MBP 2.6 ghz/4 gigs of RAM?  HAs any testing been done with this box and notebook computers?
    Bill
  • Fri, May 15 2009 10:34 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,169
    • Points 13,410
    Avid lists that MojoDX works with Macbook Pro from 2.16Ghz Intel Core Duo upto (tested) 2.53 Cored 2 Duo.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Mon, May 18 2009 9:01 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    So that means it comes with a notebook card?
  • Mon, May 18 2009 9:41 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,169
    • Points 13,410
    That's a question for someone who already has one.. or an Avid (re)seller.
    My Two Cents .02
    Kent Brockman
  • Mon, May 18 2009 9:47 PM In reply to
    I'm seeking absolute verification, but if I recall correctly, Avid will swap out the standard pci-e card for the appropriate laptop card upon request.  I do not run any laptop based systems, so I'm not %100 sure on this one.  Thus, I've asked someone upstairs and will report back when I hear for sure.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Mon, May 18 2009 9:55 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Thanks Todd,
    I would probably be interested in running it on both computers. Guess I would have to purchase an extra
    card regardless.
    Bill
    Filed under: ,
  • Tue, May 19 2009 12:48 AM In reply to
    • Jlash
    • Los Angeles
    • Posts 14
    • Points 170
    1.   To use the Mojo DX with the MBP laptop, you have to buy the ExpressCard from Avid for about $400.
    Here's what it says on the Avid site:
    <The following card slots are required for connection to the Avid Mojo DX hardware:
    • PCIe x4 slot (for workstations)
    • ExpressCard slot (for laptops)>
    Note that it says ExpressCard slot but doesn't say anything about a specific Avid card. And an ExpressCard is not listed as "in the box."   The MojoDX instructions do spell out the need for the specific Avid card.   This area of confusion has been brought to the attention of Avid Marketing and I'm surprised they haven't clarified with the redesign of the web site.  2.   Using DNxHD36 (1080p 23.976) media, the MojoDX driven by the MBP laptop will only play in the YELLOW/GREEN mode out the HDSDI port of the Mojo DX.   Not GREEN/GREEN as one might hope. In order to use a normal HDTV client monitor (1080i) using the HDMI output from the MojoDX, the video output tool has to be set to cross convert and the MBP laptop cannot successfully handle this software conversion.   Michael Phillips has some good information about this on the Film & 24P forum Neither of these limitations of the MojoDX are listed in the hardware qualification list . These limitations go away when using a qualified tower.
  • Tue, May 19 2009 3:37 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
      Moderator: Broadcast Newsroom
    Jlash is right.....
     You must purchase the laptop connection card separately and there isnt a swap program I am aware of at Avid.  I checked.
    I am going to touch base again with marketing and see if hey can make this a tad clearer on the web site.
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Tue, May 19 2009 3:45 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
    Todd made a good point... here is the Avid scoop with PN etc.
    7020-20242-01 PCIe Laptop Adaptor
    Required for MC Mojo DX on Laptop
    US MSRP $500.
    HTH
    marianna
    813-493-6800 mobile
    AOL IM avidmarianna
