My original thread has outgrown itself. Now I am starting a second Tutorial thread which will include the next 100 tutorials.I am still working on some way of indexing the tutorials so that it will be easier to find different topics.By the way, the First 100 Basic MC Tutorials can be found HERE
Link 101 Playing Unrendered EffectsLink 102 Introducing Particle IllusionLink 103 AvidFX and the Black Background PuzzleLink 104 Track Height - All the same heightLink 105 Changing the Timeline Background ColourLink 106 Changing a Bin's Font and Font sizeLink 107 The View MenuLink 108 Track Height - all the same - REVISITEDLink 109 From MC to AvidDVD - A look at the SettingsLink 110 Multi Camera Mode - 1. Just a GlanceLink 111 Before Basics - 1. Track SelectorsLink 112 Before Basics - 2. Splice-in, Overwrite, Drag & DropLink 113 Before Basics - 3. Lift & Extract from IN to OUT pointsLink 114 Keyboard Commands vs. Drag & DropLink 115 AvidDVD - Adding Subtitles - 1. Getting startedLink 116 AvidDVD - Adding Subtitles - 2. Japanese and ImportingLink 117 AvidDVD - Adding Subtitles - 3. Writing your own for import Link 118 NTSC DVD to PAL DVD to NTSC DVD Link 119 SD and HD on the same Timeline - 1 Link 120 SD and HD on the same Timeline - 2. Avid's Open Timeline Link 121 SD and HD on the same Timeline - 3. The Digital Cut Tool Link 122 4 Simple Steps from HD to an SD DVDLink 123 Using Keyframes in Effects - 2: Starting from Scratch Link 124 Using Keyframes in Effects - 3: Adding Keyframes Link 125 Using Keyframes in Effects - 4: Moving Keyframes Link 126 Audio Wave-form Height Link 127 Globally setting IN/OUT Points on Clips in a Bin Link 128 Exporting a QT Movie from Camtasia Studio for import into MC Link 129 Some Lasso Techniques Link 130 Using Keyframes in Effects - 5: Aligning Keyframes Link 131 Using Keyframes in Effects - 6: Slipping Keyframes Link 132 Using Keyframes in Effects - 7: Adding Keyframes - Revisited Link 133 Using Keyframes in Effects - 8: Deleting KeyframesLink 134 New to Transitions? You need Handles! Link 135 AvidFX - Title Tool Part 1: My First Encounters Link 136 AvidFX - Title Tool Part 2: First Encounters continue.. Link 137 AvidFX - Title Tool Part 3: Holding a Title onscreen Link 138 AvidFX - Title Tool Part 4: Add another Text-Page and some Fades Link 139 AvidFX - Title Tool Part 5: Making a Title of a specific Length Link 140 MM - 3 small Tips when using a Bin's Text View Mode Link 141 AvidFX - Title Tool Part 6: Making and using a Title Template Link 142 AvidFX - Title Tool Part 6A: Correcting a vital mistake made in Part 6! Link 143 AvidFX - Title Tool Part 7: A simple Text Roll Link 144 AvidFX - Title Tool Part 8: Animating Type-on Text Link 145 AvidFX - Title Tool Part 9: Type-on Text Revisited Link 146 AvidFX - Title Tool Part 10: The Vector Trace Tool Link 147 Holding a Dissolve at 50% for a set Time Link 148 Deleting a Clip - Revisited Link 149 Evapourating Clips! Link 150 Controlling Clip Snapping Link 151 That Puzzling Extra Frame! Link 152 Deleting a Clip - Revisited, yet again! Link 153 24 Keyboard Shortcuts to jog your Memory Link 154 Shift 'n Map Link 155 Go to Next/Previous Edit without entering the Trim Mode Link 156 Keyboard Mapping Suggestions - Focus Link 157 Zooming In/Out and dragging the Monitor Picture Uploaded November 11th Link 158 Confused by Track Selectors? Uploaded November 17th Link 159 Confused by Track Selectors? Part 2 Uploaded November 18th
Link 160 Coming soon!
Please inform me if you find any broken links.
Regards,Douglas
Link 119, was my first step into the world of SD and HD on Avid's Open Timeline.It was not exactly what many of you have been asking foir.But today I think I finally got a workflow together to output the mixed timeline as SD to a digital clip which, in my opinion, gave equally good quality to the original HD and SD material.I will try the whole workflow again tomorrow - to double check things.If all is well, I'll try and get it out as a Tutorial before the weekend.
Regards,
Douglas
Over a week and no new Tutorial!
Am I slipping? NO, I don't think so. After a week with other assignments I am now in the process of getting to grips with 2 or maybe 3 tutorials on KeyFrames in Effects.Those little red/pink triangles are sometimes hard to keep under control.............
Sounds good, I need a little info on keyframing. Anyone got some tut on color correction?
dew:Anyone got some tut on color correction?
I can give you a quick "rule of thumb" for color correction - figure out what your problem color is and where on the luminance scale it resides (blacks, midrange, whites) and use the appropriate vector circle to go in the 180 degree opposite direction of the problem color.
dew: Sounds good, I need a little info on keyframing. Anyone got some tut on color correction?
Anything here to help you get started?
http://www.avid.co.uk/uk/video/xpress/automaticColourCorrection.shtml
It is for Xpress, but I think it may be similar in MCRegards,Douglas
I enjoyed your keyframing tutes, Douglas. I wonder if you could provide a tutorial describing how to make use of the keyframing modes (apply to active parameter, apply to all, apply to open group, apply to active group). Believe it or not, I find a couple of these are confusing to use (perhaps I should read the manual ).
Thanks for the great work!
Stee
Steve
BarkinMadd:I enjoyed your keyframing tutes, Douglas. I wonder if you could provide a tutorial describing how to make use of the keyframing modes (apply to active parameter, apply to all, apply to open group, apply to active group).
Thank you, Steve.
I am planning to do another 2 or 3 Tutorials on Keyframes.I'll see what I can do about your request.
PS. Do you prefer to pay by PayPal or Credit Card?
Your a funny man....
I'm in the process of playing with keyframing - Until now I've used them in a pretty simplistic way (which has worked just fine for me) - I see the need to use more sophisticated techniques in the coming weeks.
Cheers
(Do you take Diners Club?)
This post was highlighted in the avid email newsletter. It begs the question, where are the first 100? Is there a link that we can save which would continue to show the full list, in its entirety?
ThanksBill
barebodkin:This post was highlighted in the avid email newsletter. It begs the question, where are the first 100? Is there a link that we can save which would continue to show the full list, in its entirety? ThanksBill
A good point, Bill
Actually I believe the first 100 were featured in an earlier "Avid in Focus", although at that time there were only 50. So the title may have been "50+ Tutorials"However I have taken your advice and added a link to "the first 100" in the opening post in this thread.Having all Tutorials in 1 place was proving to be too much of a strain on the system, so I decided to break it into 2.Regards,Douglas
BarkinMadd: I enjoyed your keyframing tutes, Douglas. I wonder if you could provide a tutorial describing how to make use of the keyframing modes (apply to active parameter, apply to all, apply to open group, apply to active group). Believe it or not, I find a couple of these are confusing to use (perhaps I should read the manual ).
Steve, believe it or not I also find them confusing!
But the good news is that I have been reading up on it today, and even started putting together another 3 or 4 Tutorials on them.Possibly 1 or 2 of those tutorials will be online within the next 24 hours, and the remainder by the weekend.Regards,Douglas
Douglas,
I love your tutorials, it is so helpfull. Any chance we could talk you into doing one on how to import footage from a dvd to your system? I still havnet been able to get my footage off the dvd_r to my system to cut my reel. ugh.
any help you could give would be awesome. thanks for all that you do!
The rainy season has come to Japan.It is a lot cooler now (only around 25-28 C) so my brain is beginning to work again and I finished 4 new Tutorials today Hope there is something for you in them!
Very nice job on the Lasso- my personal favorite.
http://community.avid.com/forums/p/47041/264866.aspx#264866
I'd like to use paypal to chip in for an umbrella or brainfood.
