Latest post Wed, Jun 24 2009 7:35 PM by Kevin Sio. 5 replies.
Page 1 of 1 (6 items)
  • Thu, May 7 2009 4:05 PM
    • Kevin Sio
    • Syracuse, NY
    • Posts 265
    • Points 3,285
    Options to feed new Panasonic LCD monitor
    Installed a new Panasonic 17" LCD recently.  I am currently feeding it component from my Mojo which works fine. However, I am looking for options to take advantages of its digital capabilities but do not know how or what to send it.  I don't believe I have a digital output available.  Is there any sense to somehow convert the analog component video to digital?
    thanks
    Kevin
    HP-xw8600 Media Composer 2.8 [view my complete system specs]
  • Thu, May 7 2009 4:43 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Re: Options to feed new Panasonic LCD monitor
    Kevin:
    IMO, that would be wasted time, since the analog signal will look no better converted to digital than it does right now as analog. If you don't have a digital output available, stay with component analog.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Thu, May 7 2009 5:18 PM In reply to
    • Kevin Sio
    • Syracuse, NY
    • Posts 265
    • Points 3,285
    That's kinda what I suspected.  Are my options then MoJo SDI or DX?  Is there a non-avid branded solution?
    Kevin
  • Wed, Jun 24 2009 2:20 PM In reply to
    • dbeditorial
    • Dallas, TX
    • Posts 19
    • Points 195
    I have the LH-2550 connected to NitrisDX via HDMI. Works great! I used it with the MojoDX via SDI and it did a great job of auto-sensing different frame sizes too. If you have an analob Mojo, I would not buy an A/D just to make SDI to feed the monitor, unless you have long cable lengths to deal with. The Mojo SDI offers some nice features but I doubt I would buy one just to get digital to your monitor, I doubt you would see a difference.
    Avid Symphony on NitrisDX and Media Composer on MojoDX. Both with BCC6. Protools 8.1 with Command 8 and an iLok full of goodies. Runs on a smoking fast... [view my complete system specs]
    "A person with no character has no enemies,
                                    so I prefer to make enemies."
     -- Paul Newman
  • Wed, Jun 24 2009 3:18 PM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 576
    • Points 6,210
    if you have a second pci express  port you can install a second video card and then adapt it to hdmi with a cheep adapter   then send full screen playback to it  and it works great i am sending signal to a 40 inch lg
    ps i used a nvidia gt 6500 along side my quadro 3500
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Wed, Jun 24 2009 7:35 PM In reply to
    • Kevin Sio
    • Syracuse, NY
    • Posts 265
    • Points 3,285
    Great ideas all...thanks
