Latest post Wed, May 20 2009 12:06 AM by lawsonr. 8 replies.
Page 1 of 1 (9 items)
  • Wed, May 6 2009 3:27 AM
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,238
    • Points 24,745
    Phantom Hosts in Health Monitor
    I have an odd one-   after a recent upgrade where MI's were swapped, the old engine became the lookup/GPS server, and a new engine was installed,   I have a phantom host in the health monitor.   It appears in all the health monitors,  and throws them all to red alert status, as it's not real, and therefore can't be found.
    Anyone seen this,  or killed it?
    TIA
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
    Filed under: , ,
  • Wed, May 6 2009 4:32 AM In reply to
    • lawsonr
    • Joined on Thu, Jun 8 2006
    • CBS News
    • Posts 223
    • Points 2,675
    Re: Phantom Hosts in Health Monitor
    Is it a hostname you recognize? What happens if you try to ping that machine? Something, somewhere is running Framework that you don't know about. When you set up your new GPS/Lookup, did you wipe the slate clean or uninstall MI and reinstall Lookupand stuff?
    Lastly, what version of Interplay are you using?
    Avid NewsCutter 7.1.1, ISIS 1.6, Interplay 1.5. [view my complete system specs]
  • Wed, May 6 2009 4:42 AM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    1.5,  the hostname was the original "workgroup" name-
    It's not someone running framework, as it would show processes,  this has no "friends" that way.
    this was an Uninstall the engine, and re-install lookup & stuff.
  • Wed, May 6 2009 9:38 PM In reply to
    • lawsonr
    • CBS News
    • Posts 223
    • Points 2,675
    If the phantom wasn't running Machine Monitoring service, then it wouldn't show up in the Health Monitor, correct?
    I'm assuming you changed the hostname of the system when you changed it from an Engine to a GPS. Was it a member of an AD domain? Did you unjoin the domain, also? I'm just throwing darts here.
  • Tue, May 12 2009 5:09 AM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    But if it was running the machine monitoring service, it would show processes I would think,  even just the free disk size.
    yep,  hostname changed, and we aren't active directory.   The old hostname of that GPS server is attached to the new hostname of the Primary Engine, at a different IP address.
  • Tue, May 12 2009 7:40 PM In reply to
    Hi Jeff,
    If you look in the registry settings of the LookUp server(s), there may be an instance of your old workgroup lingering.
    Look in:
    HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Prefs\avid\workgroups\avid technology incorporated\data\com\avid\workgroup\remoting\setting\groups
    There may also be a group locator folder in the key above groups:  group locators, delete that key. There should only be your current workgroup.
    Also look for and delete old hostname ServiceIDs, but Not your current/new hostname ServiceIDs.
    Deyner Seals
  • Sat, May 16 2009 5:31 AM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    I'll take a gander tomorrow,  thanks, Deyner.
    JDS
  • Mon, May 18 2009 5:08 PM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    Found it-
    Wasn't the registry,  it was an "expected machine" entry in the Lookupserver's System configuration service tab.   Removed it, and clean.
    No more false failures,   WIN.
    JDS
  • Wed, May 20 2009 12:06 AM In reply to
    • lawsonr
    • CBS News
    • Posts 223
    • Points 2,675
    Good one to know.
