Latest post Sun, May 10 2009 7:33 PM by mascotca. 4 replies.
  • Wed, May 6 2009 1:19 AM
    • dharia
    • Joined on Fri, Sep 19 2008
    • Posts 112
    • Points 1,345
    Exporting Quicktime with Timecode MC 3.5 for FCP
    How can I export a quicktime out of AVID with embedded timecode, so that I can import that quicktime into FCP and the timecode is the same?
    I want to export a source clip from a AVID bin  and have the timecode transfer, so that when its imported in the FCP I can batch capture it.
    Any idea? I heard MC 3.5 supports export to QT wit timecode
  • Wed, May 6 2009 1:50 AM In reply to
    • mascotca
    • Posts 37
    • Points 410
    Re: Exporting Quicktime with Timecode MC 3.5 for FCP
    To append another question to this one, I seem to be able now to import a QT that already has embedded TC into Avid and the TC now makes it through the import! (No more workarounds required...)
    Was this something that got added to 3.5.1?
    TIA
  • Fri, May 8 2009 3:05 PM In reply to
    TC on imported QTs was added in v3.5.  It appears, though, that exporting QTs with TC is not yet available.
    MacPro MCA (v4.0.3/3.5.9/v3.1.4) on 2x3 GHz Quad Core Xeon; Mac Meridien (v12.1.2); Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Fri, May 8 2009 4:13 PM In reply to
    • RalphFoster
    • Joined on Tue, Oct 14 2008
    • London, UK
    • Posts 28
    • Points 375
    You used to be able to use Sebsky tools for this (to add TC to a qt after exporting) but it seems to be broken in recent version of the OS.
    I've had some success with this however:
    http://developer.apple.com/samplecode/QTKitTimeCode/index.html#//apple_ref/doc/uid/DTS10004426
    It's very basic and the default is always NTSC type timecode but I have used it successfully to put a timecode on a QT that COMPRESSOR then reads to burn into the picture so I suspect FCP should read it.
    I wasn't that sure of all the settings though it's a bit cumbersome.
    4 x Software MC 2.8.3 OS X v10.4.10 QT 7.3.1 on Unity 5.0.1 Plus Standalone Intel Laptop MC 2.8.3 with Local Firewire Drives. [view my complete system specs]
  • Sun, May 10 2009 7:33 PM In reply to
    • mascotca
    • Posts 37
    • Points 410
    If you have FCP you could import your QT export and then "Modify" the "TimeCode"  and then the QT itself will have a TC track thereafter.  I think.
