Latest post Thu, Mar 27 2008 6:08 PM by triangle. 14 replies.
Page 1 of 1 (15 items)
  • Thu, Jan 12 2006 9:05 PM
    • Egg663
    • NYC
    • Posts 11
    • Points 145
    Embedded audio Question...
    Does anyone know if the Nitris supports embedded SD and/or HD audio (via SDI)... also, how many channels through each if supported?
    Eric
    Symphony Nitris DX xw8600 3GB RAM 8TB AVID RAID [view my complete system specs]
    Finishing Editor / Colorist
    PostWorks, New York
    Quote:
    Client: "I can play the uncompressed HD QT off my firewire drive, right?"
  • Thu, Jan 12 2006 9:23 PM In reply to
    • TCurren
    • Posts 1,084
    • Points 13,995
    Re: Embedded audio Question...
    Yes it does, and it works. You can do up to 8 channels. You need to enable it in the audio project settings under output. The default is disabled.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
  • Thu, Jan 12 2006 9:25 PM In reply to
    • Egg663
    • NYC
    • Posts 11
    • Points 145
    Thank you for the quick response...is the 8 ch just for HD or SD as well?
    PostWorks, New York
  • Thu, Jan 12 2006 10:15 PM In reply to
    • TCurren
    • Posts 1,084
    • Points 13,995
    Not in front of the system right now, but what does 8 channels in SD?
    Burbank, Ca
    www.alphadogs.tv
  • Thu, Jan 12 2006 10:27 PM In reply to
    • jal
    • Posts 13
    • Points 165
    Yes, but you have to turn the embedded outputs ON in the output pane of the Audio Project Settings. They are off by default.
    Input is up to eight channels in both SD and HD.
    Output can be selected to be 4 or 8 in SD, or 4, 8, 12, or 16 in HD, also set in Audio Project settings. To get 16 you have to be in direct out and turn on 16 channel output. I don't know if any decks exist that can support 12 or 16 channels.
  • Thu, Jan 12 2006 10:57 PM In reply to
    • Egg663
    • NYC
    • Posts 11
    • Points 145
    Thank you, very helpful info...
    Eric
    PostWorks, New York
  • Wed, Jan 18 2006 2:10 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 260
    • Points 2,840
    • Moderator: Avid DS
    Sony's SRW format supports 12 channels.
    M
    "There are no rules for the brave". Albert Einstein
  • Thu, Mar 27 2008 2:19 AM In reply to
    • LexTrex
    • Posts 3
    • Points 45
    Does avid have a machine template for the 5500 that supports 12 channel out.  When I select the Sony SRW 5500 60 I only get 8 audio channels.
  • Thu, Mar 27 2008 2:31 AM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 443
    • Points 5,365
    Like Jal says you can I'm not in front of a system now but we do 12 track stuff all the time. I'd go in and see but there is a conform going on in there.
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
  • Thu, Mar 27 2008 2:40 AM In reply to
    • LexTrex
    • Posts 3
    • Points 45
    I've got the Avid playing out 12 channels, no problem.  I have to manually arm my SRW during a long preroll because the Avid machine template i'm using from Symphony 1.5 only supports 8 channels.  Has anyone written a machine template for 12 channel out to an SRW?  Does one of the newer releases have an updated template?
  • Thu, Mar 27 2008 5:29 AM In reply to
    • TCurren
    • Posts 1,084
    • Points 13,995
    No. The basic Avid interface still only allows 8 channels. The deck template ISN'T the issue.
    Burbank, Ca
    www.alphadogs.tv
  • Thu, Mar 27 2008 9:33 AM In reply to
    • Neil J
    • Posts 134
    • Points 1,630
    LexTrex - can you explain a bit more clearly how you output 12 chs at once? I didn't think this was possible.
    And Terrence what is the issue with playing out 12 chs? Is it a Nitris hardware limitation?
  • Thu, Mar 27 2008 4:37 PM In reply to
    • TCurren
    • Posts 1,084
    • Points 13,995
    You can output 16 channels with Nitris over HD-SDI. If you enable the 16 channel output, and assemble edit, you will get the 16 channels on your deck.
     Avid can only arm 8 channels in the digital cut tool. If you want to insert edit any channels above 8, you need to manually arm them on the deck during preroll. Obviously this is far from optimum.
    Burbank, Ca
    www.alphadogs.tv
  • Thu, Mar 27 2008 5:52 PM In reply to
    • LexTrex
    • Posts 3
    • Points 45
    Hi Neil,
    Under the output tab of your audio project settings you will find a button that says "Allow 16 channel output."  Now under the HD-SDI tab you will see 12 channel 24 bit and 16 channel 24 bit as output choices.  They work great.  The problem is arming your VTR.  I thought the problem was the machine template.  Evidently not.  TCurren says the limitation is actually in the software for the output tool.  Mike at tech support in Tewkesbury confirms that a fix will be in an upcoming software release.
  • Thu, Mar 27 2008 6:08 PM In reply to
    • triangle
    • Posts 7
    • Points 95
