Latest post Mon, May 4 2009 6:02 PM by DIESELE. 14 replies.
Page 1 of 1 (15 items)
  • Sun, May 3 2009 7:47 PM
    • MovieMaker76
    • Joined on Tue, Mar 25 2008
    • Los Angeles
    • Posts 208
    • Points 2,685
    Frustrated. Sorenson Squeeze to Avid DVD problems....
    Ok.  So this is the issue.  I am transocding in Sorenson Squeeze.  I am using DVD NTSC 16X9_LG.  So then when I try to add it to Avid DVD by Sonic.  THis window pops up.  Now if I add it, it makes me transcode it again.  Now, if I use Adobe's Encore, it works like a charm.  But, I like Sonic more.  Anyone help....
    Intel Core 2 Duo E 6700, RAID(0), NVIDIA Quadro FX 3450/4000, 4GB ram, Vista64, MC 3.5 [view my complete system specs]
  • Sun, May 3 2009 7:49 PM In reply to
    • camoscato
    • Posts 6,079
    • Points 72,935
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Frustrated. Sorenson Squeeze to Avid DVD problems....
    What kind of file are you using in Avid DVD?
    Generally, the workflow is:
    1. Export a Quicktime Reference Movie from Media Composer.
    2. Use the Quicktime Reference Movie you exported in step 1 in Avid DVD.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sun, May 3 2009 8:02 PM In reply to
    What are you throwing into AvidDVD/DVDit? Only the video-mpg or the audio-mpg as well? If you want to go thru' Squeeze you might want to read this thread, that's how it works for me.
    Regards, g_f
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    Hello Camoscato,
    No, I can do that.  But, I'd rather transcode in Sorenson as it is better quality than avid dvd.  Also, I noticed that avid dvd chews up more space on the disk when transcoding.
  • Sun, May 3 2009 8:08 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,100
    • Points 35,420
    MovieMaker76:
    As you have the " always ask me this " box checked, you will always get this warning, even when the files are fully compliant.
    Just uncheck the box.
    If the files are compliant or not will be shown during the encoding process, do soem tests with differnt settings to see what works for you.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Sun, May 3 2009 8:21 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    mjolnarn:
    MovieMaker76:
    I did uncheck it, but now it wont import it.  And if it does it is garbled.  Why if I transcode it as an mpeg 2, does it not work?
  • Sun, May 3 2009 8:22 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    I tried QT hq and it imports fine.  But, I prefer mpeg2 for dvd.
  • Sun, May 3 2009 8:29 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    MovieMaker76:
    Nevermind on this.  it adds the media with no error, but when you make the dvd, it still transcodes the video.  Whats the point of having sorenson squeeze, if this is what happens?
  • Sun, May 3 2009 8:36 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    Does anyone know, if you transcode it in sorenson.  Then it transcodes in avid dvd.  Does that mean it is transcoding the SAME video twice?
  • Sun, May 3 2009 10:31 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,032
    • Points 25,940
    • Moderator: MCA PC
    MovieMaker76:
    ..........it still transcodes the video.  Whats the point of having sorenson squeeze, if this is what happens?
    Aha! Now you are getting closer.....  Geeked
    Maybe the following Tutorial will give some food for thought!
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Mon, May 4 2009 5:01 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,100
    • Points 35,420
    MovieMaker76:
    Yes, that is what happens if you don´t find the correct settings, might be a little tricky to find them, and , in that case, as in Douglas tuts, it is better to let Avid dvd take care of the encoding process.
    Tomas
  • Mon, May 4 2009 5:09 AM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    Thank you all.  I think you're right Douglas.  i will just let Avid transcode it in it's DVD application.  I am through trying to figure it out.
    Sincerely, you guys are all a huge help.
    Todd
  • Mon, May 4 2009 5:14 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,032
    • Points 25,940
    • Moderator: MCA PC
    mjolnarn:
    Yes, that is what happens if you don´t find the correct settings, might be a little tricky to find them......................
    Good point, Tomas.
    And, "Why", I hear you all ask,"would Squeeze not have the correct settings?"
    There are a number of possible Blu-Ray/DVD pre-sets to choose from in Squeeze.
    There are NO presets that specifically say "for DVDitProHD or AvidDVD".
    I am only guessing here, but I have a feeling that as DVDitProHD was out before the pack(as far as Blu-Ray goes)... it may have some small idiosyncrasies in what it wants for "compliant" parameters.
    Adobe Encore and some other Blu-Ray Authoring programmes may be more in line with what Squeeze is producing.
    I am mentioning Blu-Ray..... but the same may well hold for the DVD part.
    Unless it is absolutely vital for your source material I still suggest missing out the middle man. Go from MC straight to AvidDVD!
    Good luck,
    Douglas
  • Mon, May 4 2009 5:27 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,100
    • Points 35,420
    Yes, Douglas, as with most ( = all ) editing , there are very few automated workflows and a llearning curve for everything that you want to do, in this case maybe the op could start with creating maybe 10 or 20 dvd discs using the standard workflow to learn the basics and, after that, maybe, do some smalll tests with preencóding files to see if they might work without the need of beeing reencoded if the Op still feel that there is a need of using preeencoded files.
    Tomas
  • Mon, May 4 2009 6:02 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 325
    • Points 3,960
    It's definitely some setting somewhere mate.  Were you doing audio too in Sorenson?
    My workflow (until recent frustrating issues) was always to use Sorenson to make the video file m2v and import this to DVDit and link the WAV audio.   Just check out your whole export settings from Avid to Sorenson to your authoring settings.  Post 'em here if you want a second opinion, but it seems like one mismatch somewhere...  There's a lot of room for error after all!
    Diesel
    Panasonic HPX301 P2 Camcarder (sic!), MC 4.0.3, Vista 64 SP2, Asus P5K-E Mobo, Q6600 Dual Quad Core @ 2.4Ghz (3.0 Ghz if I'm up against it!), 8Gb 800Mhz RAM Dual channel, C: Raptor (can you hear it?!) Media: 4 x 500Gb SATA Stripe O pairs, P2 archive E-Sata WD x 4, Quadro FX 1500 GFX, Soundblaster Audigy, Mojo SDi.  Sony PVM CRT.  Approved Avid HP 8240 Notebook.
    VIDEO PRODUCTION SOUTH WALES CRACKING PRODUCTIONS
