i added a load filler on my keyboard settings but when i try to use it he just not worck.. there is a way to make it worcking?
Works here, just tried it for fun.
Command Palette set to Menu to button reassignment
Mouse click on the key you want to map on your keyboard setting (mouse pointer changes to a small white square with black squiggles on it)
Mouse click on left hand top of your source monitor and then on Load Filler.
Your selected key on the keyboard settings changes to "LF" Close Keyboard settings and Command Palette.
Thanks for the continued dongle support
humm yeah i did that... but the problem was before that.. i had set LF to my "]" key but when i type it nothing changes, it did not change to load filler.. nothing happen i use media composer last version
i am not sure if i missing something or if it just cant be used fom shortcuts :/
ps sorry for my bad englsh :D
Maybe a Mac thing or a MC 3.5.
I tried it on a PC MC 3.1.2 and 2 x PC 3.0.5 and it worked on all of them. I will be able to try it on a Mac MC 3 later today.
In order to get it to work for me, I have to engage/activate the Source monitor first, then hit the button I've got mapped for Load Filler.
I'm on Mac too and it's been that way probably at least since MC 2.8
hummm thx that worcking now.. but now i need another tip, there is a way to change winows inside avid with out click with the mouse on it?
like if i were using timeline and want to add a load filler then there is a way to change to source monitor w/o use the mouse?
dcaldeira:if i were using timeline and want to add a load filler then there is a way to change to source monitor w/o use the mouse?
Yes... press the Escape key. It toggles between Source and Record monitors, and will jump to the Source Monitor from the Timeline, and most other windows too (but mysteriously, not a bin!).
You can jump to the Timeline from any other window by pressing Command 0, and to the Composer Window with Command 4. Unfortunately, this will always activate the Record Monitor rather than the Source.
Hope this helps!
