Latest post Thu, Aug 15 2019 1:38 PM by Ferenc Kovacs. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Thu, Jun 23 2011 10:13 PM In reply to
    Re: Movie export from procedures FAILED!, errcode:-2034
    Just to follow up on this... i did figure out what my problem was.
    The AVCHD media I imported had some problems with it.
    I noticed my export would always crash around a certain point, so I checked that point out in the timeline, and at the end of a clip there was a second of black - and it said, error, disk limit or something.
    Either way, there were some bad clips in there, so all i had to do was delete that second of black error at the end of the clips that were corrupted, and it exported perfectly.
    Unlike me, first check all your media in the timeline. You might be surprised what you find in there sometimes.
  • Thu, May 31 2012 1:08 AM In reply to
    • TrainerDave
    • Joined on Tue, Aug 5 2008
    • Sydney Australia
    • Posts 181
    • Points 2,310
    Hi all,
    Greetings from the Great Land Down Under...
    Now I don't know if this is going to help anyone but I had this same error today using Symphony v6.  I am exporting a 30-sec CSA as an H264 QT movie with four alternate audio mixes.  The first one is called DG1878_30_v8a.mov. the second one DG1878_30_v8b.mov etc.  Versions a, c and d experted without the error but the "b" version would not.  I ended up exporting it as just DG1878_30_v8.mov and then adding the "b" after the file had been exported.  Really, really weird I know but there it is!
    Cheers,
    Dave Forsyth
    Home: Dell T3500 Win 7 Pro, MC7 with Symphony option Work: HP z820 workstation, 16Gb RAM Media Composer v7 with Symphony option) [view my complete system specs]
  • Thu, May 31 2012 12:08 PM In reply to
    • Jean Dunoyer
    • Watertown, MA
    • Posts 156
    • Points 2,015
    Software is a beautiful thing
    MacPro 2 X 2.4 GHz Quad-Core Intel Xeon 6GB 1066 MHz DDR3/Avid MC 5.0.4 OS 10.6.8 [view my complete system specs]
    DunoyerFilms.com
  • Sat, Dec 29 2012 5:16 PM In reply to
    • markle77074
    • Houston
    • Posts 332
    • Points 4,405
    i bump my head on this kind of stuff all day.
    It is a collossal waste of time.
    AVCHD is fraught with problems.
    I have several machines. My latest is a zbook with maxed out processor, memory and video card running windows 8. [view my complete system specs]
  • Tue, Jan 22 2013 12:14 AM In reply to
    • TrainerDave
    • Sydney Australia
    • Posts 181
    • Points 2,310
    Hi all,
    Just had this saome prolem myself.  I workd around it using the same method we used years ago when dealing with the old PGLUE_SAMPLE_NUM_OUT_OF_RANGE error...
    1. Load the offending sequence into the timeline
    2. Move in one frame from the head of the sequence and mark IN
    3. Move in one frame from the tail of the sequence and mark OUT
    4. Subcatalog it back to the bin
    5. Export
    All is well! But here's what is really odd.  If I load this trimmed sequence into the timeline and try exporting it again, I get the same error!
    Hmmm....
    Dave Forsyth
  • Mon, Sep 28 2015 4:01 PM In reply to
    • Ian Nicholson
    • Joined on Mon, Aug 9 2010
    • Sydney, Australia
    • Posts 65
    • Points 965
    I got this error today.
    Running MC 8.4 with a custom-sized project (1000x1310) and source material FrameFlexed from 1920x1080 (AMA linked) files.
    I had added a NewBlueFX color correction to a clip on the timeline, and got the error while trying to export as H.264 to those dimensions.
    By rendering the effects, I was able to export successfully.
    To be on the safe side, I rendered all the clips on the timeline first before exporting.
    MC 8.5.0 on Intel i7 3770K 3.8GHz, Gigabyte GA-Z77X-D3H, nVidia GTX670 2GB, 16GB RAM, 2 x 128GB SSD, 13TB disk, 2 x HP 2711x 27" LED monitors, Windows... [view my complete system specs]
  • Mon, Sep 28 2015 4:44 PM In reply to
    Always best to render up first.
    If you don;t then any renders created as part of the export process are not retained so a 2nd export has to do them all again. Render first (or video mixdown even better) then export.
  • Wed, Aug 14 2019 9:12 AM In reply to
    Hi all,
    I'm bumping up this thread because there are things that just don't change...
    I've had this error several times during the years but rendering and/or mixdowning always helped. Now we are on 2018.12.1 and I have this again: one (out of twelve) timeline can't be exported.
    After the 56th attempt the timeline is not only rendered and mixdowned, but is a brand new timeline which only contains the mixdown (both audio and video) and the codec is the same (DNxHD185x) as the export format would be. The playback of the sequence is flawless.
    Any ideas?
    HP Z420 MC 2018.12.3/2018.18.2/7.0.4 MINT server-client network [view my complete system specs]
  • Thu, Aug 15 2019 1:38 PM In reply to
    Luckily I've sorted this out (I exported small parts of the sequence according to the position of the progress bar indicator when the error occured). It was caused by a rendered effect (which was of course included in the mixdown), and the render itself contained something, something that didn't show up when playing the sequence, nor did it give an error during the mixdown, but it even got itself reproduced into the mixdown thus preventing the export of that too.
    It would be really great if someone could explain this (and fix this bug as it'll soon grow adult and demand rights).
    p.s.: I've just noticed that this is the Mac section (google brought me here). My case was on a Windows PC, but honestly it doesn't make any difference here...
