Latest post Fri, Apr 24 2009 3:54 PM by udosauer. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Apr 24 2009 2:42 PM
    • GF
    • Posts 86
    • Points 1,155
    progressive export
    Hi All
    I am exporting a 8 bit uncompressed QT and was wondering if it is possible to export it as a progressive file. First because all the material came from so many sources I did a mixdown to try and neutralize any possibility of conflicting field dominance. All the material originates from an NTSC source but was digitized DV 25 and 1:1. When I examine my options in the export window I can chose "Single field" will this setting provide me with a progressive output ? The purpose of the output is for my web demo site and I have been having alot of motion artifacting and what seems to be interlace issues when I create a flash file using my Sorenson. Also does any one know a definitive article on using sorenson to create flawless flash files from avid sequences ?  Any help would be appreciated.
    Gary
  • Fri, Apr 24 2009 3:54 PM In reply to
    • udosauer
    • Hamburg, Germany
    • Posts 113
    • Points 1,340
    Re: progressive export
    To get rid off mixed field orders just do a video mixdown. Then do your export.
    If you really want progressive frames ("film look") use a deinterlace filter, i think there is a boris-fx deinterlacer)
