Latest post Mon, May 4 2009 11:34 PM by dekafilm. 21 replies.
Page 2 of 2 (22 items) < Previous 1 2
  • Wed, Apr 22 2009 2:09 AM In reply to
    Re: Audio dissolves not playing correctly in 3.5.1 ??
    Codec Moment:
    if not 3.
    Not that way on 3.1.2 here
    Thanks for the continued dongle support
  • Wed, Apr 22 2009 4:51 AM In reply to
    • Codec Moment
    • Joined on Mon, May 21 2007
    • Philadelphia
    • Posts 314
    • Points 3,985
    Oh, my bad. I'm running 10.5.6. I forgot to update OS in my specs.
    Mac OSX 10.5.6 Avid Media Composer v4.0 soft Macbook Pro 2.5GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 SDRAM Galaxy Metal Gear Box with 2 WD Caviar... [view my complete system specs]
    I trust orange juice more than I trust most people.
  • Wed, Apr 22 2009 7:15 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    Wanted to add something as we await confirmation from a third person:
    On a subjective level, my impression is that the fades are not linear as they used to be, but instead some kind of logarithmic curve (see picture of curves from a different app, used as illustration).  The fade is very gradual until it suddenly drops off at the end.  This also seems new to me in v3.5.1.
    Anyone?
    BTW: this is true whether I change the audio settings to "constant power (-3dB)" or "linear (-6dB)."
    AVID Media Composer 3.5.1 - MacBook Pro 2.4GHz Core 2 Duo 4GB RAM - AND - ASUS P4P800E-Deluxe P4 2.6GHz, 2GB RAM, Intel 865 chipset, Windows... [view my complete system specs]
    http://www.dekafilm.com
  • Fri, Apr 24 2009 8:00 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    **Bump**
    Still waiting for at least one more 3.5 user to confirm the presence of this problem so I can escalate the issue.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Mon, May 4 2009 4:52 PM In reply to
    • skinnymc
    • Joined on Sat, Dec 31 2005
    • NYC - Available to work worldwide
    • Posts 38
    • Points 470
    Here's your third editor out. I definitely have the issue; my real time audio effects only work when rendered or if I start from an earlier position in the timeline.
    Other than that Avid 3.5.1 has been a joy.
    MCP 3.5.1/Leopard 10.5.6/QT7.6 on Macbook Pro 17" 2.4GHz Intel 4GB RAM (with a free replaced motherboard as the original had a defective videocard... [view my complete system specs]
  • Mon, May 4 2009 8:19 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    I am escalating this issue to Avid Engineering and QA.
  • Mon, May 4 2009 11:34 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    Larry Rubin:
    Thank you , thank you, thank you!  Smile
