Latest post Mon, May 4 2009 11:34 PM by dekafilm. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Tue, Apr 21 2009 8:00 PM
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    Audio dissolves not playing correctly in 3.5.1 ??
    Dissolving from audio material to filler should act like a crossfade to silence. However:
    In my new 3.5.1 installation (supported MacBook Pro 15"), what I hear depends on where I start playback (!). If I start playback from before the dissolve, it fades out more or less as expected. If I start near the end of the dissolve, it behaves more like a cut. If I start somewhere in between, the fade doesn't have time to complete: there is some reduction in volume, but it doesn't completely fade out by the end of the dissolve.
    This is a new behavior for me after 15 years with the app. Anyone else seeing it?  Obviously, I'm hoping Media Composer leaves the artistic decisions to me. Geeked
    (Oh, and before anyone tells me I should be using keyframes for mixing audio: I'm working with an editor who has never and will never use them, and we need to maintain the same technique on our shared sequences -- otherwise, I'd love to).
    Thanks!
    AVID Media Composer 3.5.1 - MacBook Pro 2.4GHz Core 2 Duo 4GB RAM - AND - ASUS P4P800E-Deluxe P4 2.6GHz, 2GB RAM, Intel 865 chipset, Windows... [view my complete system specs]
    http://www.dekafilm.com
  • Tue, Apr 21 2009 8:05 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Re: Audio dissolves not playing correctly in 3.5.1 ??
    In your audio project settings, under the effects tab, make sure the dissolve midpoint attenuation choice is for "constant power", not "linear".
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Tue, Apr 21 2009 8:13 PM In reply to
    dekafilm:
    That seems rather limiting on the other editor's part.  I mean, I often don't use the keyframes because dissolves will work, but there are some instances where a bite is really tight and you NEED to use a keyframe.
    I understand that often if you're sending to a mix house, they don't particularly like when we use keyframes, but you have to get it sounding right.
    dekafilm:
    Why can't the other editor conform to your preference rather than you conforming to his?
  • Tue, Apr 21 2009 8:34 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    Larry Rubin:
    Thanks.  This didn't solve the problem.  To clarify:  what you hear depends on where the playback bar was at the moment you pressed play.
    Anyone else experiencing this?  Can anyone reproduce it on their 3.5.1 systems?
  • Tue, Apr 21 2009 8:37 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    Kenton.VanNatten:
    Well, it doesn't help that I'm his assistant.  Smile
  • Tue, Apr 21 2009 8:53 PM In reply to
    dekafilm:
    I'm his assistant.
    Oh, you didn't mention that before.  But still, seems limiting to me.  Like trying to write a novel without using the word "the".
  • Tue, Apr 21 2009 9:06 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    Kenton.VanNatten:
    Yup.  I'm with you there!  If it were up to me, we'd have flying faders, too.
  • Tue, Apr 21 2009 9:22 PM In reply to
    Kenton.VanNatten:
    Or just a different way of working (thinking.... or not  Wink) 15 years with Avid and have never used an audio keyframe (or audio dissolve), could not even tell you how to use them.
    Thanks for the continued dongle support
  • Tue, Apr 21 2009 10:00 PM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    AndrewAction:
    You are not alone.  By far.  Geeked
    Again, to everyone out there:  can anyone confirm this new audio dissolve behavior on 3.5.1 ??
  • Tue, Apr 21 2009 10:55 PM In reply to
    dekafilm:
    Not tried on 3.5.1 here. Does it make any difference if your dissolves are rendered? (not in timeline view of your first post)
  • Wed, Apr 22 2009 12:02 AM In reply to
    • dekafilm
    • Los Angeles
    • Posts 56
    • Points 625
    AndrewAction:
    As I would expect, rendering takes care of the issue (because now it's just playing though a new file).
    So now I can either (a) park ahead of my audio dissolve to audition even just the last little bit of it, or (b) render it (with all the detritus that method leaves on the media drives over time).  Either way, it's not efficient.  I hope it's "just a bug" and that someone fixes it in a patch release...
    Confirmations?
  • Wed, Apr 22 2009 12:06 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    If two additional users can confirm this behavior with 3.5.1, I'll escalate the issue.
  • Wed, Apr 22 2009 12:44 AM In reply to
    • Codec Moment
    • Joined on Mon, May 21 2007
    • Philadelphia
    • Posts 314
    • Points 3,985
    I have the same problem. It's been here since 3.5 if not 3.
    Unrendered audio fades played from mid fade will play as cuts unless rendered or played from before the fade.
    Mac OSX 10.5.6 Avid Media Composer v4.0 soft Macbook Pro 2.5GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 SDRAM Galaxy Metal Gear Box with 2 WD Caviar... [view my complete system specs]
    I trust orange juice more than I trust most people.
  • Wed, Apr 22 2009 1:33 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    One more 3.5 user, please. Anyone?
  • Wed, Apr 22 2009 1:38 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Micah:
    Any particular reason you're not running OS 10.5.5 or 10.5.6?
