Latest post Tue, Apr 21 2009 6:36 PM by bonang. 2 replies.
  • Tue, Apr 21 2009 5:30 PM
    • bonang
    • Portland, OR
    • Posts 78
    • Points 1,000
    degraded pic in HD downconvert
    Just recently upgraded to 3.5.1 on an xw8400 / VistaBiz 64 bit, SN classic. One lingering issue is downconverted HD material - so far just 1080/30p and 1080/60i. When the HD project is switched to NTSC 30i, the downconverted video looks 1/2 res - lots of aliasing, both on client monitor (SDI or component) Always green mode, tried both 8 and 10 bit, no difference. Same if you perform a SD mixdown. This used to look great/as expected on 1.8.3 / xw8200 XPRO 32 bit SP2. Except for the host cpu, HW is same as before.
    In 3.5.1 there is an option, when HD is still the chosen format, to do a digital cut in SD -- cool -- and this video looks fine, both on client monitor and actual output. But when same project has the format changed to SD, it looks terrible. SD projects (w/ SD source) look fine, so there is something fishy in the SW/HW instructions for downconverting that is not good. Anyone else experiencing this, or tips for a fix?
    Avid Symphony Nitris "Classic" 3.5.9 | xw8400 / Vista Business 64 / FX3500 / 8GB ram Avid MC 3.1.1 w/ mojo (desktop) | Avid MC 3.5.9 (laptop... [view my complete system specs]
    Keith
  • Tue, Apr 21 2009 6:27 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 150
    • Points 1,810
    Re: degraded pic in HD downconvert
    We have this too.  I don't think it's anything new, HD just looks soft when you playback in SD mode.
    We downconvert our HD material before hand (with a Sony HDCamSR deck) if we're going to playout in PAL or NTSC.
    SYMPHONY NITRIS 3.5.4 HP xw8400 QT 7.6 Vista 64 ADRENALINE 3.5.1 PC HP xw8400 XP MC SOFT 4.0.2 PC HP xw8400 - & MacPro 3Ghz Quad OS 10.5.8 QT 7.6.2... [view my complete system specs]
  • Tue, Apr 21 2009 6:36 PM In reply to
    • bonang
    • Portland, OR
    • Posts 78
    • Points 1,000
    Thanks for the response. But this is, most definitely, new w/ this upgrade -- not so much a question of soft, as it is aliasing.
    Keith
