Latest post Sat, Jul 18 2009 12:37 AM by AndrewAction. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Apr 17 2009 9:33 AM
    • camoscato
    • Posts 6,089
    • Points 73,015
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Clock weirdness?
    I just posted on this thread:
    http://community.avid.com/forums/t/70918.aspx
    The first post, which says it was made at 9:20am (UK), was actually made at 2:20pm (UK), but the forum software put it first because that's when it thinks it happened.  I don't know if this is system-wide, or just a problem with my profile.
    If I could just have a mini-rant here for a minute, I know next to nothing about forum administration, but I'm active on three forums, and neither of the other two have the constant flakiness that this one has.  One of the forums is running on Simple Machines software, and the other on phpBB, and neither of them has anywhere near as many problems as the Telligent software this forum runs on.
    That's to take nothing away from the hard work that the Avid Community Team is doing, and I appreciate it wholeheartedly, but it's been a while that we've been on the new forum software now, and I'm not impressed with it.
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Fri, Apr 17 2009 9:47 AM In reply to
    Re: Clock weirdness?
    Pif:
    Time back to normal (new server is in a new timezone). Sorry for that.
    Oh really?
    I just posted this and quoted you "before" you even had gotten up this morning apparantly.
    And I'm with Carl here... this Forum software seems to have a ton of issues.  Slowness, Errors, Time-Stamp, etc.
  • Fri, Apr 17 2009 10:40 AM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
      Moderator: Meridien
    Posted at 1540 UK.
    [edit] Forum post time says 1040.  Kenton's right.  It's still off.
  • Fri, Apr 17 2009 11:36 AM In reply to
    I just posted at 8:35am PDT, and the time-stamp is 3:32am ... and the post didn't float to the top ...
    Also Pif, what happened to being able to use colored text?  And, cutting & pasting a URL doesn't produce a link anymore?
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Fri, Apr 17 2009 12:12 PM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
      Moderator: Meridien
    1711 UK time stamp 1211
  • Fri, Apr 17 2009 2:25 PM In reply to
    • Pif
    • Avid Tewksbury
    • Posts 191
    • Points 2,150
    • SystemAdministrator
  • Fri, Apr 17 2009 6:28 PM In reply to
    Test at approx 1330 EDT
  • Fri, Apr 17 2009 6:36 PM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
      Moderator: Meridien
    1835 UK
    Seems like it's working again.
  • Sat, Jul 18 2009 12:37 AM In reply to
    Is the forum clock ever going to operate correctly to its base reference of GMT (as suggested in the time setting in your portfolio setup). In my experience it is always an hour out and seems to work on British standard time (i.e. affected by British daylight saving. Or the local time of the server compared to GMT where local time has a daylight savings parameter) not GMT. Here this means that if I correctly postion myself as GMT +12 (local standard winter time) I am an hour out. If the clocks time was actually referencing GMT this would not be the case.  (I first discussed this 2 or 3 days after the updated forum was created October 2005)
    Thanks for the continued dongle support
