Latest post Fri, Apr 3 2009 11:53 AM by Clement Canino. 4 replies.
  • Thu, Apr 2 2009 8:34 PM
    • maxvideo
    • Posts 47
    • Points 580
    SDI to analog converter for MojoDX
    I'm looking for a SDI to analog and analog to SDI converter for MojoDX.
    For me, at this moment it can be usefull for sending:
    -  SD/SDI video signal  via converter  to analog / Y/C for instance /
    - HD/SDI  video  signal downconverted to SD  and output  via converter  to analog / Y/C for instance /
    Audio is send directly from MojoDX / via TRS connectors /or via converter.
    I'm thinking about Broadcast Converter from the Blackmagic Design. At the Blackmagic www I have heard: "it is the best converter...", but I prefer users opinions :-)
    Anyone using Blackmagic? Any problems? Maybe another solution...
    Thank's in advance.
    MC MojoDX 3.5.1, WinXP SP3,QT 7,6, HP XW8600 workstation / 2xXeon Quad Core 3,0 GHz, NVidia Quadro 3700, 4Gb RAM / Atto UL-5D SCSI controller with external... [view my complete system specs]
  • Thu, Apr 2 2009 9:13 PM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 654
    • Points 7,960
    Re: SDI to analog converter for MojoDX
    AJA may have something ...
    MC Nitris DX v.4.0.2 HP Z800 * Nitris DX v.4.0.2 HP wx8400 [view my complete system specs]
    So my new wife asks me about my "Avid Forever" tattoo... I told her she's an old girlfriend who was always coming up with new things for me to try...
  • Thu, Apr 2 2009 9:18 PM In reply to
    • maxvideo
    • Posts 47
    • Points 580
    vvp:
    Do you prefer AJA over Blackmagic ?
  • Thu, Apr 2 2009 10:07 PM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 654
    • Points 7,960
    I've never used anything from Blackmagic to date.  Although I've never heard anything negative about them.  AJA gear has served me well though when I've needed it so far.
  • Fri, Apr 3 2009 11:53 AM In reply to
    Yes, the BMD Broadcast converter would prob do it for you, thought about getting one for my MojoDX, but kept the old analog mojo anyway. Had a BMD Multibridge pro, worked great, except I had to use Premiere, so now I have the DX. Better using Avid..BMD tech support is very good btw,, then so is AJA's . I'm not sure if  AJA's FS1 I  can do what you need too, not sure about simultaneous conversion,  but I'd check with both MFRs before making a purchase.
    HP XW6400, 2x 3.0 dual Xeon 4g ram, Quadro FX 3500, XP Pro SP2 Pyro 64, MOJO, MOJO DX, latest nvidia drivers from Avid install disk, recommended QT version... [view my complete system specs]
