Latest post Thu, Nov 19 2009 9:45 PM by postmark. 38 replies.
Page 1 of 3 (39 items) 1 2 3 Next >
  • Wed, Apr 1 2009 10:40 PM
    • postmark
    • Posts 65
    • Points 920
    audio mix tool must be updated!!! please vote!!
    1: Allow the avid to remember when it has imported a stereo file - and always gang the faders for its tracks together on the audio mix tool. But also allow that link to be turned off when wanted.
    2: Make the audio mix tool show all tracks at once. No more switching to "Grp 2"
    3: Allow timeline tracks to be assigned as stereo/mono and gang faders togther automatically. This would over-ride the clip setting described above.
    If you do only these things my hands and wrists will thank you very much.
    MC 3.5/Mac OS10.5.7 2ghz iMac Software Only [view my complete system specs]
  • Thu, Apr 2 2009 1:20 PM In reply to
    • itmatters
    • Joined on Mon, Jan 23 2006
    • Posts 306
    • Points 3,570
    Re: if you do nothing else, please do this...
  • Sat, Apr 25 2009 3:57 PM In reply to
    • postmark
    • Posts 65
    • Points 920
    Please, if you want this - add your voice to this thread. Every day I click hundreds of times when I shouldn't have to. It's such a basic need for improvement.
    I'll add to this request also - please make it possible to adjust the volume of a track *while listening to it* - don't stop the timeline from playing when clicking on the mixer levels. I'm not talking about recording a mixdown - I simply want to change the one overall level on a clip while monitoring it. I don't want to memorize the fader moves I make while adusting the level.
  • Thu, May 28 2009 9:34 PM In reply to
    • eddieb
    • Joined on Fri, May 2 2008
    • Ontario, Canada
    • Posts 21
    • Points 330
    Oh, yes, Please! Both the ganging of stereo pairs and the ability to listen to and change a level or EQ.
    MC 4.02 Nitris DX xw8600 4GB Quadro 3700 169.47 Vista64 QT 7.6 Unity 5.1 [view my complete system specs]
  • Fri, May 29 2009 6:41 PM In reply to
    • NubusAvid
    • Joined on Fri, Mar 3 2006
    • Kent U.K.
    • Posts 126
    • Points 1,435
    I loudly, and in ganged stereo, add my voice to this request;
    even though my finger is worn out already today from all those extra unneccary mouse clicks.
    MCA 4.02 DNxHD card Macpro Quad 3Ghz 3Gb Ram Apple Fibrecard Infotrend 15Tb Sata raid 5 Fibre chassis. Panasonic TH-50PF9UK Monitor Yamaha 03D Mixer... [view my complete system specs]
  • Fri, May 29 2009 7:03 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    Add my vote for it as well.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Wed, Jun 3 2009 8:36 AM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 816
    • Points 9,735
    I would had a great feature found in Liquid. The ability to right click on a clip in the timeline and open it's clip properties. Then, the ability to change the clip's settings from stereo to mono, etc.
    You can even do that on multiple clips at once, directly in the timeline.
    ASUS P5W DH Deluxe, Intel Core 2 Duo E6600 2.4 GHz (OC at 2.87GHz), 4G DDR667, NVIDIA 8600GT 512 MB (Softmod: Quadro FX 1700), Media Composer 3.1.3.2,... [view my complete system specs]
    Sylvain Primeau Primeau Medias. Self-employed worker. Formerly television tech editor.
  • Wed, Jun 3 2009 4:54 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,787
    • Points 57,000
    Yes this was awesome in L.
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Wed, Jun 3 2009 6:51 PM In reply to
    • Schmidtsk
    • Joined on Thu, Jan 18 2007
    • Cape Town South Africa
    • Posts 55
    • Points 655
    Yes Please! I have been caught many times with changing levels on the ganged channels on the invisible group. A very un-Avid arrangement. Audio Mix tool should automatically reflect and provide control of all the channels in the timeline. Pretty obvious really.
    Don't know why I haven't griped about this before, so thanks postmark!
    MacPro 2.66, 3GB, MC 3.1.2 (OSX 10.5.6), Mojo. Also on G5 2.0, 2GB [view my complete system specs]
    Plant a tree
  • Fri, Jun 5 2009 9:28 PM In reply to
    • postmark
    • Posts 65
    • Points 920
    It's good to finally see people voting for this! Thanks to all. I might now be able to put off wrist surgery.
    Let me be a bit more specific on the last point. My scheme for this option would mean being able to set pairs of adjacent odd/even tracks (1/2 - 3/4 - 5/6 - 7/8 etc) as either being ganged together or not.
    Actually I guess it would be even better to be able to gang even larger blocks of tracks together. I'm getting more and more 4 channel audio from the field these days. Maybe put a pulldown menu on the mixer for each track that can add check marks next to the tracks you want to gang with it. Then come up with a nice way to visually indicate which tracks are ganged together. Colors or something? Perhaps the colors from the timeline tracks? Then another button on the mixer to toggle the ganging on and off for each group.
    It would be oh so nice to set a balance between different tracks from the same source (such as a few lavs from different people) and then be able to vary that group's overall level at once.
    One note on the ganging - tracks which have been set to 0 (infinity / completely off) should stay that way, even if a member of its gang is moved. Then only way to get a track like that back in action would be to turn ganging off and raise its level.
    But I still would like Avid to remember when it has imported a stereo file and gang its tracks together by default. Perhaps there should be an import setting that specifies whether you are importing a stereo or multiple mono files.
    Oh, and when the avid imports a single track file, please have its pan set to center by default, not left.
  • Sat, Jun 6 2009 11:39 AM In reply to
    • redsnapper
    • London, UK
    • Posts 38
    • Points 460
  • Sat, Jun 13 2009 3:03 PM In reply to
    • editmk
    • Joined on Mon, Sep 10 2007
    • Posts 94
    • Points 1,235
    My vote too.
    HP XW8400 Dual Quad Core 2.6 Ghz Vista 64 12 Gigs of Ram 14TB of Raid 10 sata storage Media Composer 3.51 SDI Mojo Twin Dell 2408 Widescreen Monitors... [view my complete system specs]
    www.mikegreen.tv
  • Sat, Jun 13 2009 4:36 PM In reply to
    • conleec
    • Los Angeles
    • Posts 661
    • Points 8,620
    postmark:
    [snip]
    I'm getting more and more 4 channel audio from the field these days...
    [snip]
    I'll throw my support behind these ideas.
    Also, for years now, I've been saying I'd like to have separate routing control in the source and record (ie, the timeline) monitors.
    Because it is getting very common to receive 4 channel audio from the field, I'd like to be able to leave the source monitor on direct out, routed to channels 1 thru 4, so I can hear them individually and decide which track(s) I want to cut in. But then I'd like the ability to preset pans and channel routing independently on the timeline. For instance, it'd be great if I could set the timeline to stereo playback, routed to channels 5 and 6, say, while leaving the the source in direct out.
    I'd like the ability to set tracks 1-8 on the timeline to default to center-pan, then let higher pairs (ie 9/10 and 11/12) alternate L/R for music.
    Actually, now that I think about it, just separate routing control over source and record would allow us to do this all at the outboard mixer.
    MacPro 2.66Ghz 8 Core (Nehalem), 6Gb RAM, nVidia GeForce GT 120, Adrenaline HD, Leopard 10.5.8, MC 4.0.3, QT 7.6.2 [view my complete system specs]
  • Sat, Jun 20 2009 6:10 PM In reply to
    • postmark
    • Posts 65
    • Points 920
    I agree with these further refinements! But please also leave it flexible for those of us without an outboard mixer - something that also is becoming more common. I actually prefer losing the outboard mixer - we should be able to route everything we need - to a point - with the avid software.
    I also remember something that has frustrated me over these long years with avid.
    I never can seem to determine which source channels have been used in the timeline. It would be nice to use the timeline text display function to display the orignal source channel in addition to reel number, etc.
  • Mon, Jun 29 2009 11:21 PM In reply to
    • dbeditorial
    • Dallas, TX
    • Posts 19
    • Points 195
    This is a great idea! Auto-Gang the imported faders anddo something in the timeline tokeepthem in synch.
    Avid Symphony on NitrisDX and Media Composer on MojoDX. Both with BCC6. Protools 8.1 with Command 8 and an iLok full of goodies. Runs on a smoking fast... [view my complete system specs]
    "A person with no character has no enemies,
                                    so I prefer to make enemies."
     -- Paul Newman
