Latest post Fri, Mar 27 2009 7:36 PM by nicov. 2 replies.
  • Fri, Mar 27 2009 6:08 PM
    • daryl5
    • Israel
    • Posts 181
    • Points 2,570
    Embarrassed [:$] how to mix between progressive and interlaced material in one project
    Hi
    I have a project that i need to edit it is a lot of events that need to be edit and export to a DVD until now all the materials came from one camera that is DVC-200 in dv format as interlaced so i work with 25i project
    now i also get materials that come from HVX-200 as in mini-dv tape or on P2 card as DVCpro50 and as i know it is all in progressive (and all are in PAL)
    so how can i mix them all in one project and still export the end product to a DVD and so that it will look ok as i know from a test i did if i work in 25p in avid and all the materials are interlaced  when i export it to a dvd it look bad.
    so for that i need your help how to solve this problem.
    Tamir
    Xw8200 dual 3.8 Xeon 5GB of memory 2x1TB Sata HDD Mojo [view my complete system specs]
  • Fri, Mar 27 2009 7:04 PM In reply to
    • bee gee
    • UK
    • Posts 523
    • Points 6,225
    Re: hot to mix between progressive and interlaced material in one project
    AFAIK, you can't mix frame rates in the same project. I would stick with your interlaced project, and use a progressive plugin for the material that's interlaced - something like 3-Prong's Speedramp gives great results and is pretty cheap. Or you could use Avid's own Fluidfilm plugin, but be prepared for long renders.
    xw8600 dual quad 3ghz, MCv3.0.5, 4gb ram, xp pro, fx3700, Adrenaline DNA, Seagate 2TB internal raid'0', WD 250gb boot, Blu-ray writer [view my complete system specs]
  • Fri, Mar 27 2009 7:36 PM In reply to
    • nicov
    • Joined on Wed, Jun 7 2006
    • Posts 135
    • Points 1,610
    Re: how to mix between progressive and interlaced material in one project
    Yes, fluid film or BCC deinterlace that comes bundled with MC.
    OSX 10.5.5 / MC 3.1.3 / Mojo DX / octo 2.8 Macpro / 6g ram / Ati 2600 + Ati 3870 / 2x Nec 19' + JVC DTV24 / Sony HVR M15 / 2To sata raid0 / [view my complete system specs]
