Latest post Mon, Mar 30 2009 4:19 PM by MikeyB. 17 replies.
  • Wed, Mar 25 2009 2:29 PM
    • MikeyB
    • Posts 41
    • Points 530
    Problem playing old media in v3.5
    I've got some old DV clips I want to use, but when I try to play them I get a black screen in the Source monitor with the error message:
    "Decompression error in clip (clipname) error 36"
    where (clipname) is the name of the clip I'm trying to play.
    If I view the bin in Frame view, the clip frames are all scrambled.
    The media was captured into Xpress Pro v4.x originally, can't remember exactly which version.  It's NTSC 29.97fps DV411 compression, OMF format.
    I've also tried importing the OMF files into a new project, rather than just using the existing OMF folder.  The import process goes OK, but still the same error when I load and play the clips.
    I've tried using both my Mac and my WinXP systems, both give the same error.
    Any ideas?
  • Wed, Mar 25 2009 2:38 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Re: Problem playing old media in v3.5
    MikeyB:
    I know this is not what you want to hear, but that usually indicates corrupted files.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Wed, Mar 25 2009 4:46 PM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    Larry Rubin:
    Well, they were ok last time I used them!
    Interestingly, if I export any of the clips as QT Ref using the Avid DV codec, I get nothing - just black, when played in QT player.  If I export as QT ref with Use Avid DV Codec unchecked, I can play the clip in QT player without any problems.  I can then re-import the QT ref and Bingo, the resulting clip plays fine in Avid too! So I think the 'corruption' is more likely an issue with the Avid DV codec than the media.
  • Wed, Mar 25 2009 11:21 PM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    is the error 36 or -36.  if its -36 that usually refers to the scsi chain.  try rendering to the mac internal drive as a test
  • Thu, Mar 26 2009 7:32 PM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    No it's definitely "error 36" and not -36.  I've also tried copying the OMFI MediaFiles folder to another drive - same result.
  • Thu, Mar 26 2009 7:52 PM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    What kind of project have you tried to open them in?
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Thu, Mar 26 2009 9:21 PM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    I've tried both NTSC 30i and 1080i 59.97. I've tried deleting the media databases as well.  They re-build without any error message.
    As I say, exporting QT refs of the clips without the Avid DV codec selected results in playable media in QT player, suggesting there's nothing basically wrong with the media.  I'm thinking I'll have to roll back to an older version and see if that helps (thankfully I'm still using a dongle.....).
  • Fri, Mar 27 2009 12:03 AM In reply to
    • Gardiner
    • New York
    • Posts 29
    • Points 365
    Long shot, but is the older AVID DV411 QT component (codec) installed? In the past when using an AVID codec QT file on a computer that does not have that particular codec you would get white or black on playback. Not sure this is the case, but it did come to mind...
    2 x G5 (Dual 3GHz Quad Core), 17GB RAM, OS 10.4.3, MC 2.8.3 [view my complete system specs]
    Owner/Editor gabba media, llc 119 W.23rd St., Suite 500 New York, NY 10011 (212) 741-9630-main (x.14) (212) 741-9693-fax http://www.gabbamedia.com gardiner@gabbamedia.com
  • Fri, Mar 27 2009 9:11 AM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    Good question.... I've been a good boy and uninstalled the old version of MC before installing the new.  I've also made sure to use the recommended version of QT, so I expect I've got the latest Avid DV codec installed.
    Today I've tried using a v3.05 Media Composer (running on a PC, if it mattwers) at a place i work sometimes. The media plays just fine on this system.
    It all looks like to me like an issue with the DV codec in v3.5.
  • Fri, Mar 27 2009 10:20 AM In reply to
    Mikey,
    Any chance you can upload the smallest file you got there?  I'd like to test this issue and send it on to Avid if I see it as well.  I just pulled back media digitized as 3-1 omf in 2006... not sure what version if MC I was running at that point.  It worked fine.  Not comparing apples to apples I know, but still.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Fri, Mar 27 2009 12:52 PM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    Hi Todd,
    Gladly... how do I do it?
  • Fri, Mar 27 2009 1:13 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Mikey:
    Under the options tab in the reply field, click on "add/update" under file attachments and browse to the file from there, then click "save" and post.
  • Fri, Mar 27 2009 5:01 PM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    OK, here's one of the files...
  • Fri, Mar 27 2009 6:48 PM In reply to
    Do not see it Mikey... can you upload it to a location of your own and then send me the URL?  You can send it to via chat here on Avids forums to keep the location private.
  • Sat, Mar 28 2009 10:38 AM In reply to
    • MikeyB
    • Posts 41
    • Points 530
    Ok, let's try again.  It failed because the system doesn't allow .omf files to be sent!  I've cheated and renamed the file .mpg - I hope it's fooled it.  Obviously, just put the extension back to .omf.
    Thanks for your concern!
