Latest post Fri, May 1 2009 4:57 PM by Kenton.VanNatten. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Mar 24 2009 12:00 PM
    • danczer
    • Joined on Tue, Mar 24 2009
    • Posts 2
    • Points 50
    help remembering shortcuts
    I bought Av Xpress about 2 months ago and im finding it really hard to remember any of the keyboard shortcuts! Its really slowing down  my editing speed and it looks a bit unprofessional wen i take ages to either click through the process or when i mess up the keyboard shortcuts. Does anyone know any tips or tricks on how to remember the shortcuts easier/quicker?
  • Tue, Mar 24 2009 12:04 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Re: help remembering shortcuts
    Here are the keyboard shortcuts for Media Composer. With very few exceptions, your shortcuts should be pretty much the same.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Tue, Mar 24 2009 12:56 PM In reply to
    You could invest in a color-coded Keyboard also.
    But, I'm a firm believer that repetition is the best memory device.  So, just use the shortcuts and use them often.
  • Tue, Mar 24 2009 1:16 PM In reply to
    As a lazy hunt and peck typist moving constantly between Avid and Protools I use colour coded keyboards.
    For my mapped F keys I have made up (in Illustrator) narrow keyboard sized printouts on thin card descriptors for my F keys and another of my shift F keys.  I trim these to fit on the keyboard above and below the F keys. These are easily moveable when I switch between Avids.
    Thanks for the continued dongle support
  • Tue, Mar 24 2009 1:40 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Yes, either a color coded keyboard (preferred) or adhesive key cap labels will be a huge help committing those to memory.
  • Tue, Apr 28 2009 1:15 PM In reply to
    Hey so i had a similar problem around 6 months ago and my lecturer at uni linked me to a company that sells sticker sets and silicone covers that go on your keyboard. They have all the shortcuts for avid printed on the keys so u dont need to remember anything! It has sped up my editing time 10 fold and now when im working for clients i can breeze through the shortcuts with out any pauses
    you should definitely try it out
    www.editorskeys.com
  • Tue, Apr 28 2009 1:44 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    But apparently only for Mac keyboards, none for PC?
  • Tue, Apr 28 2009 2:51 PM In reply to
    • redsnapper
    • London, UK
    • Posts 38
    • Points 460
    I would remap the keyboard to the way you like to work. Set it up in a way that makes sense to you and then it will work the way you expect it to without having to get your head around someone else's idea of a good keyboard layout.
  • Fri, May 1 2009 4:48 PM In reply to
    • yale
    • Joined on Thu, May 15 2008
    • West of Hollywood, but east of Santa Monica
    • Posts 173
    • Points 2,090
    This may not help you too much in the short term, but I found a good way to remember the shortcuts is to repeat the letter of the key in your head every time you press it.  It's a habit I got into in my early days working with Avid.  I set up my keyboard the way I liked it, then every time I would execute a command sequence on the keyboard I would think to myself what the letters were instead of the command.  I came to think of my extend edit button as P for "pull", my overwrite button as B for "build", my match frame button as N for "Natch Frame" (my M key was taken already! Big Smile), and so on.
    While I had keycaps on my keyboard originally, I soon got to the point now where I no longer need or care about having a color coded keyboard, since all of the commands are letters in my head.  The extra benefit is that I can rapidly string these commands into sequences without having to think about it.  For example, to extend the head or tail of a clip I park the playhead where I want it and type GIP or GOP.  To trim, I do the same thing and type TIX or TOX.  It almost becomes more like typing than pushing individual buttons.  By thinking this way my speed has dramatically improved.
  • Fri, May 1 2009 4:57 PM In reply to
    yale:
    That's great advice and I suppose I sort of have done the same thing although not quite deliberately.  For example, I have F8 as my Subclip, but SHIFT+F8 is Match Frame, mostly because I think the icons looked similar enough to me.
    But some others I have are
    • F5 for Filler (using the "F" sound for association)
    • SHIFT+F5 for Add Filler to Start
    • F6 for Audio Mix(er)
    • P is for Locator (because I call it a "peanut")
    • ? = Find Bin.
    there are probably more, but I can't think of them right now.
