Latest post Fri, Mar 20 2009 4:40 PM by curiosity. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Mar 19 2009 8:46 PM
    • postmark
    • Posts 72
    • Points 1,075
    double click a track to enable its selection button
    How about rather than always having to move all the way to the track selection button to click it, let us turn the button on and off simply by double clicking anywhere on the track itself?
    MC 3.5/Mac OS10.5.7 2ghz iMac Software Only [view my complete system specs]
  • Thu, Mar 19 2009 8:51 PM In reply to
    Re: double click a track to enable its selection button
    That would interfere with double clicking on segment effects to reveal nested contents.
  • Fri, Mar 20 2009 6:13 AM In reply to
    • curiosity
    • Boulder, CO
    • Posts 832
    • Points 10,505
    Only if you are in segment mode. Otherwise it could turn on/off a track.
    i7-5820(x99), 64GB, Win 8.1, GTX 1080ti [view my complete system specs]
  • Fri, Mar 20 2009 6:24 AM In reply to
    Map the keyboard.
    I have a named keyboard settings using Shift F2 ... shift F9 for equivalent audio track numbers and shift 1.... shift 9 for equivalent video track numbers.
  • Fri, Mar 20 2009 12:18 PM In reply to
    • postmark
    • Posts 72
    • Points 1,075
    Thanks for the workaround suggestions but there are times when I don't want to have to hit a key to enable tracks. And it's true, you have to be in red or yellow arrow mode to have a double click open up effects.
    In normal editing mode, a double click on a track does nothing. Why not have it do something useful? BTW, I would define a double click in this case not by time between clicks, but whether the position bar has moved.
    Actually it would be better if a double click selected only the specific track and turned off the others rather than just toggling the button.
  • Fri, Mar 20 2009 4:40 PM In reply to
    • curiosity
    • Boulder, CO
    • Posts 832
    • Points 10,505
    I agree with Postmark on this - but the behavior should follow the same as for the Track Light panel. If you hold the Control Key down it inverts all the tracks, if you hold the Shift key down it enables/disables all the tracks.
