Latest post Thu, Mar 12 2009 9:19 PM by Kenton.VanNatten. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Mar 11 2009 11:48 AM
    • elracador
    • Joined on Thu, Aug 17 2006
    • Paris, France
    • Posts 23
    • Points 360
    Resize Effect Problems
    Hi!  Here's my problem
    I have a project :  720x576 in Pal 25p. The original video was HDV (1920 x 1080) and it was converted with the I-link of my Sony Z1 while importing into AVID Media Composer 3.0.
    When I try to resize a shot and I render it, the surface of the image becomes sinusoidal  like it was a problem of interlacing or deinterlacing but more waveform (in a visual sense).
    If i resize it more or less the problems seems to be bigger or smaller but never totally desappear.
    Does anyone knows what is that and how to fixe it?
    Thanks.
    Daniele
    OS: Windows XP Professional CPU: Intel Centrino Core Duo 2,4 Ghz RAM: 4 Gb HD: 160 gb + External sata/firewire 2.5" HD 320 gb (MXF are in there) Video... [view my complete system specs]
  • Wed, Mar 11 2009 12:37 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,385
    • Points 15,850
    Re: Resize Effect Problems
    Many options here: check the Media creation settings to make sure You're not rendering at a low res compression; go to the Render settings and set Effects quality render using Highest quality; promote Your effect to 3D and click on HQ in the effect editor; use the console command setresizetype 9 (need to enter it everytime You relaunch MC; hope this helps.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Wed, Mar 11 2009 12:42 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,385
    • Points 15,850
    You can also check the last post HERE.
    peace luca
  • Thu, Mar 12 2009 9:53 AM In reply to
    • elracador
    • Paris, France
    • Posts 23
    • Points 360
    I've checked avery single think you said: Render Settings on Highest Quality, 3D Effect on HQ, I've tried to rotate of one frame ( as in the link you gave me), I've tried the render option as Interpolated field,Duplicated field,Original Preference.
    The problems seems to be worst then ever once all these things setted up.I got waves everywhere on my image.
    I've started having this problem with the MC 3.0 Version. Never had it before with any version.
    I really need someone to give the solution or I don't know waht to do. The problem is that I cannot resize and I have to (because of a micro in the upside of the shot).
    Is there anyone out there with the solution.
    I'm starting thinking that MC 3.0 has a bug...
    Help!!
    Thanks.
    Daniele
    Filed under: , , , ,
  • Thu, Mar 12 2009 10:52 AM In reply to
    Have you tried capturing the footage to an HDV or DNxHD project and resizing it there? Does the same problem happen?
    P4 3.0. 4 Gig RAM, CAS 2.0. 3Gig patch. Intel 865PERL mobo. Two WD 7,200 IDE drives. SIIG SATA II-150 PCI RAID card w/ 2 WD Raptor 10,000 SATA drives as... [view my complete system specs]
  • Thu, Mar 12 2009 10:59 AM In reply to
    • camoscato
    • Posts 6,071
    • Points 72,855
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi Daniele,
    Can you take a screen shot and post it for us to see, or does it only happen on moving video?
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Thu, Mar 12 2009 4:15 PM In reply to
    • elracador
    • Paris, France
    • Posts 23
    • Points 360
    Here a screen shot that I uploaded. In fact the screenshot is much more clean than if is on moving video. Much more. But it let you see what I mean.
    You will find here the screen shot.
    http://community.avid.com/members/elracador/files/default.aspx
  • Thu, Mar 12 2009 6:57 PM In reply to
    • camoscato
    • Posts 6,071
    • Points 72,855
      Moderator: Meridien
    Looks like an interlacing problem.  I don't have enough experience with progressive projects or HDV to say for sure what's going on.  Hopefully someone will chime in.
    good luck,
    Carl
  • Thu, Mar 12 2009 7:18 PM In reply to
    I would try applying a Fluid Film timewarp Input interlace Output  progressive using 100% speed effect on a very short clip (still in its native HDV format) that displays the problem and see what improvement you get.
    To the best of my knowledge version 3 was the first to allow interlace footage in progressive projects.
    If I had your problem on a lot of clips I would complete my edit in a HDV format project. Do a mixdown of the pic locked sequence and edit that into a duplicate of your pic locked timeline. Then apply the interlace to progressive effect to the mixdown and take a night (or two) off as it renders. Check this sequence and if happy with it resize and export as whatever final format you want (720 25P?)
    Thanks for the continued dongle support
  • Thu, Mar 12 2009 8:25 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,385
    • Points 15,850
    elracador:
    You're not resizing: You're cropping. Your screenshot really looks like You've interlacing artifacts anyway, none of my previous suggestions will fix that.
    peace luca
  • Thu, Mar 12 2009 9:19 PM In reply to
    Wait a second....
    elracador:
    If you shot it on the Z1, then you're footage is interlaced, right?  (AFAIK, there is no 1080/25p setting in Sony equipment)
    elracador:
    Your project is 25p.
    Why wouldn't you have just brought the footage into a 1080/50 project and then "flipped" to 25i?
