Latest post Mon, Mar 2 2009 1:21 PM by Baklap. 4 replies.
  • Sat, Feb 28 2009 7:03 PM
    • lbaker1234
    • Joined on Thu, Jan 24 2008
    • Posts 7
    • Points 95
    video capture w/dsr-500
    I have been given a laptop at work with avid xpress pro loaded in it . It I am trying to capture Video from a SONY DSR-500ws Camera. It has a Firewire but the avid does not see any input. Looked around the internet see this has been a problem, but can not seem to find a solution. has anyone solved this? Thanks
  • Sat, Feb 28 2009 7:47 PM In reply to
    • camoscato
    • Posts 6,076
    • Points 72,920
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: video capture w/dsr-500
    It would help to know your system specifications.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sat, Feb 28 2009 8:21 PM In reply to
    • lbaker1234
    • Posts 7
    • Points 95
    this is a company computer that is used for BPJ i know it worked ok but it can not find the DSR-500 I tried generic dv device and some sony settings but they do not have that setting on the pull down menu. thnaks
  • Sat, Feb 28 2009 8:52 PM In reply to
    • camoscato
    • Posts 6,076
    • Points 72,920
      Moderator: Meridien
    So that's a "no" on the system specs?
    good luck,
    Carl
  • Mon, Mar 2 2009 1:21 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,825
    • Points 80,630
    it would help to know what is in the system. For example if the firewire card is from a certain brand we might be able to tell you if it ever will work.. without that info we are as helpless as you.
    Menno
    MC 3.5.1 Test-Intel Core2Duo 6800,GTS8800 Nvidia,Realtek HD, 21" Samsung display [view my complete system specs]
    Dutch AV forum
