Latest post Fri, Aug 14 2009 1:09 PM by Job ter Burg. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • Wed, Apr 1 2009 1:38 PM In reply to
    Re: bug with clip color
    St.John, I'm just curious, do you have SD/HD enabled as well? and are some of your clips differing resolutions?
  • Wed, Apr 1 2009 2:28 PM In reply to
    • Bloersch
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 164
    • Points 1,975
    Yes, the filler changes the color after add edit.
    MC 3.1.3, OSX 10.5.5, MacBook Pro 17'', 2.33 GHZ Inter Core 2, Mojo SDI, e-Sata HDD [view my complete system specs]
  • Wed, Apr 1 2009 3:56 PM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    Kenton, only SD and all dv 420 resolution.
    Also this was fine in 3.05
    St.John
    Mac pro 2.66 GHz 2gb ram OSX 10.4.11 qt 7.4.5, MC 3.05,mojo gtech drives firewire 800 connection Mac pro 2.8 6gb ram, OSx 10.5.5 QT 7.5.5, MC 3.05 Nitris... [view my complete system specs]
  • Wed, Apr 1 2009 10:21 PM In reply to
    Okay, what you're seeing St. John, I would say is not normal behavior.  The other stuff others are seeing (where Filler changes based on what color the clip is that is directly under it's head) has been there since at least XDV I'm pretty sure.
  • Fri, Aug 14 2009 1:09 PM In reply to
    FWIW, I have been seeing the "regular bug" on a multitude of versions and systems, including SN 1.7, 1.8, 3.0, 3.1, 3.5 and their MC sibling versions on both Macs and PC's. Effects like CC and Mask appear to automatically change to the color of any clip below them at their starting point.
    It used to work differently on older systems, IIRC.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
