Latest post Fri, Feb 27 2009 1:13 AM by engr.jpc. 3 replies.
  • Thu, Feb 26 2009 9:03 AM
    • tonys
    • Joined on Thu, Jan 11 2007
    • Posts 42
    • Points 590
    correct way of daisy chaining videoraids ?
    It may be a dumb question but if I have the latest atto scsi boards (these have 2 ports) installed in my  xw8400 & xw8600's, when connecting 2 x videoraids, should I have 2 seperate cables leaving the atto board and going into each videoraid OR should I have 1 cable leaving the atto board going into 1 videoraid and daisy chain it to the second videoraid ?
    the manual is not clear
    thank you
  • Thu, Feb 26 2009 2:14 PM In reply to
    • engr.jpc
    • Joined on Wed, Jan 31 2007
    • Posts 127
    • Points 1,545
    Re: correct way of daisy chaining videoraids ?
    For a single channel HBA, 2 videoraids can be connected using daisy chain method and putting terminator on the 2nd raid.
    Since you're using a dual channel HBA, you can connect them in 2 ways (just like what you're thinking): 1) same as for single channel connection (daisy chain method). 2) by connecting 2 cables from HBA going to each videoraid and placing terminator on each raid. I think this way gives better performance or data transfer as twice as the 1st connection. Just make sure to set the correct SCSI IDs like 0 & 1.
    ISIS 1.4 (80TB) -- Iplay 1.4 -- 5 Assist -- 10 MC(Adrenaline) 2.8.4 --30 MC(MOJO-SDI) -- Sym 1.8.4 -- 16 PT HD 7.4 -- Workstations: HP xw8400, 4G RAM... [view my complete system specs]
    JPEC
    Systems Engineer
  • Thu, Feb 26 2009 4:32 PM In reply to
    • tonys
    • Posts 42
    • Points 590
    I thought I should ask becase on the drawing in the user manual it just shows the disks daisy chained and there is no mention of using both ports of the hba.
    cheers anyway
  • Fri, Feb 27 2009 1:13 AM In reply to
    • engr.jpc
    • Posts 127
    • Points 1,545
    Here, we use it in either way.
    JPEC
    Systems Engineer
