Hello,
I'm importing a batch of m2t files I captured using Firestore & Sony Z1.
99% went fine, but otheres, i get an error:
"Exception: AudioElementaryStreamParserRep::Finish....nothing int he free queue..."
Any ideas about this?
What version of the Media Composer are you using?
The only frame rate that currently supported is 1080i/59.94. Could these have been recorded at a different frame rate?
Can MPEG Streamclip open the files? You might be able to rewrap or transcode the files so they import.
-- Bob Russo Applications Specialist at Avid Technology
I used the same frame rate/format as the others that imported fine.
Yes. I had to export it to QT using MPEG Streamclip but I also had to buy the $20 plug-in.
Any ideas about that error? could it be a timecode glitch/skip?
It's an MC 3.1.1
If its the same frame rate and format, I have no idea what the issue could be. Could the clips be corrupt?
As far as the plug-in; are you talking about the MPEG 2 playback option for OS X?
That is correct.
so i had to export the m2t files to huge QT files before i can import it to Avid.
I just realized I have a tape backup that I could've simply captured!
Oh well....digital/memory hype!
(I shot HDV with a Z1 and FirestorePro)
