Latest post Mon, Feb 9 2009 3:30 PM by DMcL. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Feb 9 2009 2:01 PM
    • DMcL
    • Joined on Tue, Jan 3 2006
    • Posts 190
    • Points 2,455
    Render question....
    Working in 1.8.4 Nitris, 1080i 59.94.  I have a matte key corner bug that normally is a realtime effect(green dot).  When I layback to tape (digital cut) it is making me render the effect.  Never had this before....a bug...no pun intended...???  I never had to render when going to digital cut before with realtime effects.  Isn't that an adrenaline thing?  I've simplified the sequence and rebooted and all the other tried and true remedies.  Hmmmm...any thoughts.  Thansk.
  • Mon, Feb 9 2009 2:20 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,669
    • Points 21,300
    Re: Render question....
    Is the bug promoted to 3D?
    Do you have High Quality turned on in your render settings?
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Mon, Feb 9 2009 2:33 PM In reply to
    • DMcL
    • Posts 190
    • Points 2,455
    No to 3D.  Yes, to high quality.  I tried other render settings but it doesn't change.  Hmmm
  • Mon, Feb 9 2009 2:38 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    When you engage the high quality mode (HQ on the effects editor), the effect becomes blue dot, meaning it MUST be rendered - it is no longer a real time effect. This is normal behavior.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Mon, Feb 9 2009 2:42 PM In reply to
    • DMcL
    • Posts 190
    • Points 2,455
    No blue dot.  It's Monday.  I forgot I moved the bug slightly to the left and therefore it has to be rendered!  Thanks for your help.  Dumbass Monday.  Cheers.
  • Mon, Feb 9 2009 3:24 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,669
    • Points 21,300
    Just a move shouldn't make it have to be rendered. But the HQ settings will.
    Burbank, Ca
    www.alphadogs.tv
  • Mon, Feb 9 2009 3:30 PM In reply to
    • DMcL
    • Posts 190
    • Points 2,455
    Yeah, that's what I thought.  I put the bug back on with no move AND HQ and it didn't need to be rendered.  Go figgya.  I'm laying back now and I'll check the settings again.  It sure is Monday.  Cheers. thanks for the help.
