Latest post Fri, Feb 6 2009 10:27 PM by Larry Rubin. 2 replies.
  • Fri, Feb 6 2009 4:39 PM
    Firewire (1394) without Mojo
    I am running Avid Express Pro 5.7.5 on a PC with no Mojo. I am using the Panasonic HVX p2 camera. I can pull the files from the p2 cards with no problem. I am now working on a project where the media is on tape. I have tried to capture the tape media through firewire with no luck. What should my deck configuration be? Am I doing something wrong? Is this even possible without a mojo on this version of Avid?
    Sergio
  • Fri, Feb 6 2009 10:04 PM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 590
    • Points 7,680
    Re: Firewire (1394) without Mojo
    channel should be OHCI (or whatever - not in front of Avid) and then specify the camera.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Fri, Feb 6 2009 10:27 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    Sergio:
    Go into your user settings and first, make sure you are displaying "all settings" (check the hamburger fast menu). Then go to deck configuration. Under channel, you should have "Firewire on OHCI" and that should be linked to a machine template for the Panasonic HVX p2, if you can find it on the list of machine templates. If not, link the channel to "Generic DV NTSC Device". This is the only channel to machine association you should see in the configuration window.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
