Latest post Sun, Oct 4 2009 10:54 PM by drbgaijin. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Thu, Jan 29 2009 8:41 PM
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 590
    • Points 7,680
    Can I "up rez" 29.97DV project to 1080p size?
    Howdy forum...I think Avid has an uprez affect, but don't know anything about it.
    Basically, we have a few shorts all shot on HD in a 29.97 1080p project.  I have one 29.97 project shot on the DVX-100.  I'd like to uprez to 1080p size just so they are all happy together on the DVD.
    Is this possible?  Any help so appreciated!
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Thu, Jan 29 2009 8:48 PM In reply to
    Re: Can I "up rez" 29.97DV project to 1080p size?
    BCC that comes with MC 3 has an uprez effect that some say does a great job.  Not had much luck with it here. (Takes too much experimenting with the settings  to get a good result for my liking)
    Thanks for the continued dongle support
  • Thu, Jan 29 2009 8:55 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,105
    • Points 35,485
    Yes the uprez filter works great, you cannot capture the Sd media to be able to use it, you have to import it as a file using import settings to keep the origin size.
    After that, you just apply the filter, lots of nice settings and well described in the help file once opened it up.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Thu, Jan 29 2009 10:14 PM In reply to
    • jasperfdo
    • Los Angeles
    • Posts 590
    • Points 7,680
    Thanks...so it is an effect I have to install separately for MC 3.x?
    When you say you cannot use the captured media, does that mean I have to export same as source from the SD project and then reimport the file into an HD project and uprez?
  • Thu, Jan 29 2009 11:15 PM In reply to
    jasperfdo:
    Did you install Boris BCC that came with your MC 3 update?  If your upgrade version did not include third party apps I think Avid made a package of all the third party software for $295 or so.
    jasperfdo:
    Yes and as the mjolnarn said you need to set the import options to maintain the actual pixel size of the import. (You end up with a small picture on a black background in your source monitor)
  • Fri, Jan 30 2009 3:22 AM In reply to
    • jasperfdo
    • Los Angeles
    • Posts 590
    • Points 7,680
    awesome - thanks for the comments!  I do have the boxed version of MC 3.0 and found the Boris CD.  Installing now...
    BTW - anyone on Windows that uses MacDrive has to disable MacDrive or the Boris installer will not launch.  I couldn't figure it out at first, but since the CD is for Mac or Windows, MacDrive was grabbing it first but then not launching the Mac installer obviously.
  • Fri, Jan 30 2009 4:31 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 255
    • Points 3,050
    jasperfdo:
    I had the same problem, then I found you can just right-click on the "Mac" CD in Explorer and one of the options is "show Windows CD" (or something like that).
    cheers,
    Campbell
    3.0.5 on a mongrel PC, Win XP SP3, QT7.5, Quadro FX1400, 2Gb RAM, 2x500Gb internal SATA drives, Macdrive 7 and a Mac formatted WD 250Gb laptop drive in... [view my complete system specs]
  • Fri, Jan 30 2009 7:58 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,105
    • Points 35,485
    jasperfdo:
    Magic Sharp is the preset that gives you the best results, unfortunately, it is also most render intensive, take a loong coffee break ...
    Tomas
  • Fri, Jan 30 2009 8:29 AM In reply to
    • bsuttie
    • Edinburgh, Scotland
    • Posts 681
    • Points 8,625
    As your aim is to produce a DVD would your time not be spent better trying to get the best downconversion of the HD stuff, rather than upconverting SD to HD to downconvert back to SD?  I suspect it will suffer in the process.
    regards
    Brian
    Symphony, Adrenaline, Xpress Pro [view my complete system specs]
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Fri, Jan 30 2009 8:38 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,105
    • Points 35,485
    bsuttie:
    Correct Brian, my head is so filled up with bluray right now that I didn´t notice that he should "only" export to dvd, of course, if that is the fact, there is no need at all for upscaling the Sd clips to Hd with some filter, this procedure is only for outputting Sd as Hd.
    Tomas
  • Tue, Feb 3 2009 9:26 PM In reply to
    • jasperfdo
    • Los Angeles
    • Posts 590
    • Points 7,680
    This new Boris effect worked really well - thanks for the input!  It took letterboxed DV footage and uprezzed to 1080p anamorphic.  Pretty amazing.  The render took like 4-5 hours on a Symphony Nitris system, but it was worth the wait.
    I need this HD even though the result was a DVD as everything else in this documentary style project was HD.  So burning the DVD with one project standard def was just going to cause headaches.
  • Wed, Feb 4 2009 6:10 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,105
    • Points 35,485
    Yes i think that it is a very good filter, nice that it worked well for you.
    Actually so good that I created a little tutorial, I am not at all going to compete with my swedish talking japanese friend Douglas and as I wanted both hands free, I used a headset that I might have got for free together with a dial up modem many years ago, I use it for Skype.
    I might put it on its on page for downloading if any user finds it informative, I really like this filter.
    and, for those knowing me, it is a Silverlight clip of course, I made it big to be able to see all the details, I might create a smaller one also,  for those with better eyes and slower connections
    Boris Uprez Filter Tutorial
    Tomas
  • Wed, Feb 4 2009 7:58 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 816
    • Points 9,735
    Useful tutorial, thanks.
    ASUS P5W DH Deluxe, Intel Core 2 Duo E6600 2.4 GHz (OC at 2.87GHz), 4G DDR667, NVIDIA 8600GT 512 MB (Softmod: Quadro FX 1700), Media Composer 3.1.3.2,... [view my complete system specs]
    Sylvain Primeau Primeau Medias. Self-employed worker. Formerly television tech editor.
  • Thu, Feb 5 2009 3:54 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,105
    • Points 35,485
    Thanks Sylvain, I used a little higher speed and resolution for the file than in my standard web profiles, thought it needed to be sharp, did it play and download in a reasonable way.
    Tomas
  • Thu, Feb 5 2009 4:08 AM In reply to
    Thanks interesting tutorial. Really blurry here on a 24 inch LCD running native at 1920:1200
