Latest post Mon, Feb 2 2009 10:27 PM by Mike A. 14 replies.
Page 1 of 1 (15 items)
  • Thu, Jan 29 2009 8:01 PM
    • mhrziwnatzki
    • Joined on Thu, Jan 29 2009
    • Vancouver, B.C.
    • Posts 5
    • Points 75
    MC 3.05, How to? Absolute Source Timecode
    working on animated show.
    looking to display the source clips' absolute frame counter with timecode generator in MC 3.05.
    i can set up source clip's absolute timecode, but not frames. what  am i missing?
    please advise,
    regards
    m
    2 x 3 GHz Dual-Core Intel Xeon 4GB of 667 MHz DDR2 FB-DIMM Mac [view my complete system specs]
  • Thu, Jan 29 2009 9:13 PM In reply to
    • signedbit
    • Joined on Wed, Oct 1 2008
    • Posts 19
    • Points 215
    Re: MC 3.05, How to? Absolute Source Timecode
    Can you access the information in the source monitor? If so, what are you value are you setting their?
  • Thu, Jan 29 2009 9:16 PM In reply to
    • signedbit
    • Posts 19
    • Points 215
    Try Frames->Absolute in the timecode plugin.
  • Thu, Jan 29 2009 9:24 PM In reply to
    • mhrziwnatzki
    • Vancouver, B.C.
    • Posts 5
    • Points 75
    Hey, thanks for getting back so fast.
    move the x,y locators in the record monitor, but im not sure what you mean by putting the values there.
    and in regards to the ABSOLUTE setting in the FRAMES version of the effect, there is no drop down for choosing ABSOLUTE, I/O, MARK IN MARK OUT or anything like the TIMECODE version has. the drop down menu for that simply dissapears when choosing FRAMES as a modifier.
    any ideas?
    cheers
    m
  • Thu, Jan 29 2009 9:34 PM In reply to
    • mhrziwnatzki
    • Vancouver, B.C.
    • Posts 5
    • Points 75
    I may not have been super clear in my first post, so let me describe the results i am looking for.
    basically i am looking for each shot to display what frame is being used from the source shot.  so if i cut into the shot at 19 frames, it would start there in the TC display of that shot.
    right now, all i can find is something similar, with SOURCE > CURRENT TRACK > ABSOLUTE, but that gives me a HH:MM:SS:FF  timecode, which is not so clear for animators which frames are being used. have to use a calculator for each shot.
    doing animation its a valuable commodity to display what frames of the original shot is being used, so i was hoping this version of MC would have this component to its TC Gen. I'm probably missing something, I find it hard to believe that Avid would overlook this.
    cheers
    m
  • Fri, Jan 30 2009 8:13 AM In reply to
    • RalphFoster
    • Joined on Tue, Oct 14 2008
    • London, UK
    • Posts 28
    • Points 375
    On V2.8.3 we are setting each clips DPX field to -00000 which gives a pretty good frame counter in the timecode window and in our cutlist.
    If DPX or another feet& frames counter was available in the display plugin you could use that.
    4 x Software MC 2.8.3 OS X v10.4.10 QT 7.3.1 on Unity 5.0.1 Plus Standalone Intel Laptop MC 2.8.3 with Local Firewire Drives. [view my complete system specs]
  • Fri, Jan 30 2009 11:00 AM In reply to
    • camoscato
    • Posts 6,089
    • Points 73,015
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    mhrziwnatzki:
    i am looking for each shot to display what frame is being used from the source shot.  so if i cut into the shot at 19 frames, it would start there in the TC display of that shot. right now, all i can find is something similar, with SOURCE > CURRENT TRACK > ABSOLUTE, but that gives me a HH:MM:SS:FF  timecode
    Above the soure and record monitors there are drop-down menus for changing the display from timecode to frames.  I'd try changing those two displays to frames, then to absolute, and see if that allows you to set the timecode generator to absolute frames.
    If you've already done that and it's not working, then I have no other ideas.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Fri, Jan 30 2009 12:13 PM In reply to
    I don't seem to be able to pull such a thing off here either. Think it would make a good feature request on the feature request forum. Actually, it would be nice to be able to display anything in the Burnin that can be displayed in the Timecode Window.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Fri, Jan 30 2009 3:55 PM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    I'm using 3.1.2, and unless I'm doing something wrong:I can get a burn-in of frames: using the generator effect and the display set to frames, I think I get what is asked for, see attached photo
    St John
    Mac pro 2.66 GHz 2gb ram OSX 10.4.11 qt 7.4.5, MC 3.05,mojo gtech drives firewire 800 connection Mac pro 2.8 6gb ram, OSx 10.5.5 QT 7.5.5, MC 3.05 Nitris... [view my complete system specs]
  • Fri, Jan 30 2009 5:02 PM In reply to
    But that's not the frame count for the source shot, only for the timeline.
  • Fri, Jan 30 2009 8:03 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 261
    • Points 2,950
    According to that picture that's the V1 TC track readout as frames isn't it?
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Fri, Jan 30 2009 8:07 PM In reply to
    • mhrziwnatzki
    • Vancouver, B.C.
    • Posts 5
    • Points 75
    weird hey? I'm suprised this hasn't come up before from animation houses. it would be very valuable to post a quicktime of the show with all each shot's source details.
    and you're right, you should be able to title effect display any info that would be in the timecode display options. interesting. i wonder how hard it would be to toss that in there.
  • Fri, Jan 30 2009 9:47 PM In reply to
    You just need change TC to frames in the source drop down menu.  See attached pic.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Fri, Jan 30 2009 10:38 PM In reply to
    • mhrziwnatzki
    • Vancouver, B.C.
    • Posts 5
    • Points 75
    ah yes, that does give me the details for the source's frame count for me in my avid.
    but what would I do for making a TC burn in that details each shot's frame count,  so I can export it into a quicktime?
    thanks for your help btw.
  • Mon, Feb 2 2009 10:27 PM In reply to
    • Mike A
    • Joined on Sat, Jan 5 2008
    • Posts 24
    • Points 260
    I don't have an answer to this, but I've also been wondering the same thing. I also wish it were possible for the Timecode Burn-in effect to let you use any of the fields in the Timecode display. I deal with dual-system synced sound a lot and I wish there were an easy way to get a Soundroll and Sound TC burn-in, since our telecined tapes are always clean. Also, a way to turn off the "N.A." that appears when it can't find the information - perhaps an option to hide display when no information is detected.
    Mac Pro / Leopard 10.5.5 / Media Composer 3.1.3 / Fibrejet SAN [view my complete system specs]
