Latest post Thu, Jan 29 2009 5:09 AM by gumbycat99. 4 replies.
  • Thu, Jan 29 2009 12:04 AM
    • jennnnnnn
    • Joined on Tue, Nov 25 2008
    • Posts 8
    • Points 150
    swap transition
    I'm wondering if there is a transition in Avid that will create the effect of one video image swapping places with another.  I don't mean a spin or push or wipe.  I mean, something where you literally see the outgoing clip move, for example, to the lower left corner as the incoming clip is revealed, then moves into the foreground from the upper right corner.
    I hope that makes sense :/ Final Cut has this transition, it's called "Swap Slide"
    I know I could just use 3D warp or something to reposition my clips as needed over time, using keyframes and all that, but I could save a lot of time in this and in future projects (as I'm sure I will want to do this again), but if I could just drag one transition over onto my timeline, it would be a little slice of heaven.
    Thanks for any help!
  • Thu, Jan 29 2009 3:35 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 257
    • Points 3,060
    Re: swap transition
    Not sure if there is an effect to do what you want (unless one of the Boris Continuum transitions does it), but if you make an effect you like with 3D Warp (or whatever) you can save it for future use by clicking on the pink icon at the top-right of the effects editor and dragging it to a bin. Rename it so you know what it specifically is.
    I have a bin of effects that I've created (some as effects and some as sub-sequences with a stack of effects) that I keep on a USB stick and carry round with me. Wherever I'm working I can open the bin and drag the effects onto clips.
    Similar to the Favourite Effects in FCP, but you organise it yourself.
    cheers,
    Campbell
    3.0.5 on a mongrel PC, Win XP SP3, QT7.5, Quadro FX1400, 2Gb RAM, 2x500Gb internal SATA drives, Macdrive 7 and a Mac formatted WD 250Gb laptop drive in... [view my complete system specs]
  • Thu, Jan 29 2009 4:05 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    Re: swap transition
    Here is a short tutorial showing you what Campbell is talking about.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Thu, Jan 29 2009 4:27 AM In reply to
    • jennnnnnn
    • Posts 8
    • Points 150
    Re: swap transition
    The video doesn't play on my comp.  But I understand what Campbell is describing.  Looks like that's what I'm gonna have to do.
    Thanks!
  • Thu, Jan 29 2009 5:09 AM In reply to
    • gumbycat99
    • Posts 257
    • Points 3,060
    Re: swap transition
    No prob.
    cheers.
