Latest post Wed, Jan 28 2009 7:09 AM by Job ter Burg. 3 replies.
  • Tue, Jan 27 2009 8:24 PM
    • kutter
    • Joined on Sun, Jun 17 2007
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    1080p/29.97 on MCSoft MAC
    I have a student that shot a short film on 16mm, had it telecined to 1080p/29.97. It was captured on a Symphomy Nitris 1.8.3. The footage was then moved to a firewire drive. The student is using MCSoft 3.1.1. Mac. Also, the firewire drive that has the mxf folders on it is pc formatted. So, not being able to use the Symphomy Nitris to do the edit, any thoughts as to how he can edit the footage?
    Kent
    hp workstation xw8200, SP2, 4 gbs ram, 3.40ghz, Symphony Nitris 1.8.3, XP Pro, QT 7.3.1 MCSoft 3.0.1 Apple G5 dual 2.0 O. S. x 10.4.11 ... [view my complete system specs]
    Kent Kreiger
    ACI
    Kreiger Post - Metropolitan Post
    http://www.kreigerpost.com
  • Tue, Jan 27 2009 8:39 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,837
    • Points 201,265
    Re: 1080p/29.97 on MCSoft MAC
    You don't need the SN. The footage should be compatible with his MC Soft.
  • Wed, Jan 28 2009 3:11 AM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    So, my student will start a new projects in 1080i/59.94 and then import in the 1080p the footage, is this correct?
    Kent
    Kent Kreiger
    ACI
  • Wed, Jan 28 2009 7:09 AM In reply to
    There should be no need to import. If you copy the media to an HFS+ formatted drive, and have the Avid MediaFiles folder at its root level, you create a project, create a new bin, open the Media Tool and drag the clips into a bin. And start working.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
