Latest post Thu, Jan 15 2009 4:43 PM by TowerFan. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jan 13 2009 8:16 PM
    • Nickmarios
    • Joined on Tue, Aug 26 2008
    • Posts 6
    • Points 90
    Burning question - Sorensen Squeeze - no sound
    Is there an ideal way to burn Avid sequences with Sorensen? I am exporting them via Quicktime Movie and burning as .m2v. The picture comes out fine but there is no sound. What am I missing? Thanks, Nick Phillips
  • Tue, Jan 13 2009 8:20 PM In reply to
    • TowerFan
    • Joined on Sat, Apr 22 2006
    • Orange, CA
    • Posts 157
    • Points 2,040
    Re: BURNING QUESTION - SORENSEN SQUEEZE - NO SOUND
    m2v is a video only file. When exporting from Sorenson you probably have "Elementary" selected. You should be getting a m2a file as well, which is the audio. Add the m2v and the m2a to a timeline in your authoring program and you should have video and sound. as an alternative, select "Program" and you'll get an mpeg file that contains video and sound.
    I'm assuming you are compressing for DVD. Correct?
    MC 3.0 + Mojo, XHA1, XPPro, Intel Q6600, Intel 975XBX2KR, 4gigs DDR2, PNY FX1700, Onboard T.I. IEEE1394, Soundblaster Live! 24bit, 160gig SATA2... [view my complete system specs]
  • Tue, Jan 13 2009 9:21 PM In reply to
    • kutter
    • Joined on Sun, Jun 17 2007
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    You'll get a better looking file and a quicker eport from Avid if you export FROM Avid as a 'Quicktime Reference' file. Then compress with Sorensen.
    Kent
    hp workstation xw8200, SP2, 4 gbs ram, 3.40ghz, Symphony Nitris 1.8.3, XP Pro, QT 7.3.1 MCSoft 3.0.1 Apple G5 dual 2.0 O. S. x 10.4.11 ... [view my complete system specs]
    Kent Kreiger
    ACI
    Kreiger Post - Metropolitan Post
    http://www.kreigerpost.com
  • Wed, Jan 14 2009 10:38 AM In reply to
    • Nickmarios
    • Posts 6
    • Points 90
    Thanks TowerFan - that was very helpful and compressing in Program mode worked as you said. The only thing is now I can't get the 'burn to DVD drive without menus' option to work despite ticking the right boxes, I got it to work with the m2v file only, but even that didn't work every time so again I must be missing something. It means I have to put the mpg file through yet another process in Sonic which seems a waste of time - so any ideas? Thanks, Nick
  • Wed, Jan 14 2009 5:44 PM In reply to
    • TowerFan
    • Orange, CA
    • Posts 157
    • Points 2,040
    I'm not a Sonic user, I use Encore, so I can't help you there. Sounds like you need the disc to start playing a timeline without having any menus? When I did use Sonic, DVDit 5 I think, it had a "First Play" option, like Encore does. If so, just set the timeline you need to play as "First Play". This probably doesn't help you much though if Sonic changed the way that works. Cheers!
  • Wed, Jan 14 2009 8:46 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,385
    • Points 15,840
    Nickmarios:
    I export QT reference and let Sonic do the encoding (bypass Sorenson), You get playback settings on the bottom right corner.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Wed, Jan 14 2009 9:38 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    luca.mg:
    I'd like to add my voice to Luca's in suggesting that users try bypassing Sorenson.
    I realise that becasue of the many combinations of codecs/resolutions/formats/ etc. etc. that for some (Many?) it will be necessary to go through Sorenson.
    Also there are some who don't like waiting until Sonic does the transcoding........ whereas they don't mind waiting until Sorenson has done it - in the belief that they are saving some time making compliant files.
    My thoughts have always been that Sonic is written to do its own transcoding (where necessary) so hopefully it is designed to do that in an efficient manner.
    Sorenson is a great programme with many possible settings - that can give rise to human errors!
    If you are going through Sorenson, and you have a spare moment one day, take some time and try going direct into Sonic via QT reference files.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Thu, Jan 15 2009 1:16 AM In reply to
    • Nickmarios
    • Posts 6
    • Points 90
    Dear TF What I meant was that there is a a workflow option in Sorensen which is 'Burn to DVD without menus'. It activates your DVD burner automatically after squeezing files if you tick the right dialog box - at least it should do but I've only got it to work occasionally with m2v files so I need to know how to make it work consistently with mpg files. Nick
  • Thu, Jan 15 2009 4:43 PM In reply to
    • TowerFan
    • Orange, CA
    • Posts 157
    • Points 2,040
    Can't help you there, Nick. Didn't even know that option exists in Sorensen. Have to take a look though, seems like a good option for quickly testing the results on a TV, if it works that is...
