Latest post Thu, Jan 15 2009 7:38 PM by lawsonr. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Wed, Jan 7 2009 11:09 PM
    • mrjo18
    • Joined on Wed, Jan 7 2009
    • Posts 7
    • Points 115
    big problem with my unity !!!!! pls help me
    hello all ...
    pls help me ???
    i have 5.0 unity and i make recovery for the unity when i put the recovery dvd he ask me if i want to format c,d drive and i click yes c and d !!!! when it finish the recovery i try to open the admin tools but is give me erorr ( cannot connect to file manager ) what i can do pls help me because the was many important data on the raid !!!!
    thanx
  • Thu, Jan 8 2009 12:04 AM In reply to
    Re: big problem with my unity !!!!! pls help me
    First, I highly recommend you hire an Avid Unity ACSR or other qualified service technician to assist you.  Or, if you don't have Avid Support, you can buy a Per-Incident Support Case for $500.
    Next, to explain where things are on Unity 5.  The HDD is divided into 3 partitions.  The first has no drive letter and points to a folder named, "AVIDONLY".  The second two are C: and D:.  The MetaData resides on that first partition.
    Prior to running the Avid Product Recovery, did you manually try to reformat or repartition the HDD?  If you repartitioned it, or reformatted that 1st partition, then your MetaDatra is probably lost.
    If you look at the partitions, in Disk Management, you should see the first partition, with no drive letter, and named "AVIDONLY".  If not, it is possible to get Windows to point to that folder again, but I'd suggest you get professional assistance with that.
    Just curious though, what caused you to run the Product Recovery?
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Fri, Jan 9 2009 4:58 AM In reply to
    Hmmmm .... a day and a half and no response from the OP?  Either it wasn't really a "big problem", or he fell on his sword after realizing what he'd done :)
  • Fri, Jan 9 2009 6:16 AM In reply to
    • engr.jpc
    • Joined on Wed, Jan 31 2007
    • Posts 127
    • Points 1,545
    I think he's facing the aftereffect of what he had done.. I had a chance to use the product recovery of Unity for few times when I encountered upgrade problem but I only re-imaged C partition. In his case I'm not sure why he  needed to recover the D partition. Idea
    ISIS 1.4 (80TB) -- Iplay 1.4 -- 5 Assist -- 10 MC(Adrenaline) 2.8.4 --30 MC(MOJO-SDI) -- Sym 1.8.4 -- 16 PT HD 7.4 -- Workstations: HP xw8400, 4G RAM... [view my complete system specs]
    JPEC
    Systems Engineer
  • Fri, Jan 9 2009 10:57 PM In reply to
    • mrjo18
    • Posts 7
    • Points 115
    am sorry !
    but not i am who make the recovery the stupid IT person in the company who make this !!!
  • Fri, Jan 9 2009 11:08 PM In reply to
    OK.  So, how's it going?
    Oh, yeah, and as a general rule, you never EVER want to let the IT guys work on your Avid gear.
  • Fri, Jan 9 2009 11:13 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    Our internal DOD IT department is quite content to leave our Avid Network alone, as they fully understand that they don't at all understand Avid and it's very specific needs. We have our own engineers who maintain our Avid LAN completely isolated from the rest of the in house DOD computer network.
    I suggest that you need an on staff specialist or at least one on call, as Randall recommended. Perhaps that person can help you convince your IT people not to meddle in things they don't understand.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Fri, Jan 9 2009 11:17 PM In reply to
    • mrjo18
    • Posts 7
    • Points 115
    same problem :s!!
    i try to call the avid support in my country ... i hear about tool name pmr tool do u know what it is ?
  • Fri, Jan 9 2009 11:23 PM In reply to
    PMRtool.exe is a utility that will trash all the visible media database PMR files.  It facilitates rebuilding the media databases.  However, I'm not sure that's your problem.
    If you open "Server Log Viewer", what dioes it say?  Has a Drive set been found?  Did a MetaSet load?  Did the mount complete?  In Admin Tool, do you see anything?  Workspaces, Users, etc?
  • Fri, Jan 9 2009 11:33 PM In reply to
    • mrjo18
    • Posts 7
    • Points 115
    yes the amount is complete and the i can see the drivers in the server log viewer ... but when i try to open the admin tools there is a msg box "cannot connect to the file manager"
  • Sat, Jan 10 2009 6:01 AM In reply to
    • briMestone
    • Joined on Fri, Nov 18 2005
    • San Francisco
    • Posts 109
    • Points 1,245
    Does "cannot connect to the file manager" happen on the Unity Client? or from the Server it self?
    i have seen this problem in person before, and still digging into my memory banks on how i fixed it.
    Try Opening Admin tool from Client(Fiber) and Server.
    Ted
    2x Unity 5.1 with 7 MediaArray XT,2x Symphony DX, 20x MediaComposer DNA/DX, 20x 8Core-Harpertown, 2x 8Core-Nahalem, Protool HD [view my complete system specs]
    Ted Simbajon
    http://www.tedsimbajon.com
    Head Janitor
  • Sat, Jan 10 2009 6:05 AM In reply to
    • briMestone
    • San Francisco
    • Posts 109
    • Points 1,245
    If im not mistaken, your Unity Client can mount Unity Drives, and your problem is that the Admin tool from the Client Side can't connect "Connect connect to the File Manager".
    can you confirm this?
    Ted Simbajon
    Head Janitor
  • Sat, Jan 10 2009 11:58 AM In reply to
    • mrjo18
    • Posts 7
    • Points 115
    yea i confirm do u how to fix that?
  • Sat, Jan 10 2009 2:52 PM In reply to
    • briMestone
    • San Francisco
    • Posts 109
    • Points 1,245
    Optimize all the partition from the Administration tool (server side). Then after that... run ASM (just run READ TEST) .. then Reboot the Server...
    Ted
    Ted Simbajon
    Head Janitor
  • Sun, Jan 11 2009 6:49 AM In reply to
    • mrjo18
    • Posts 7
    • Points 115
    how i can do that ?? i cant access the admin tool >> how i can access it from the server side and what the ASM is?
