Hello Everyone!
I have noticed that when I am in effects mode and click anywhere in the timeline except on another effect, the effect editor closes and requires re-opening to edit another effect. I never noticed this behavior in XpressPro and have done a search through this site and my settings to see if I have something "turned off" that was on by default previously, but I haven't been able to find anything.
Brad
Tis normal behavior.
You could hotkey the editor in order to make it easier for you to open/close.
any particular reason why?
f there's no effect, the effect editor has nothing to do...
If you work in a toolset, open the effect editor and "save current" in the toolset menu, the effects editor should stay open as long as you're in that particular toolset.
Hi Larry,
I thought the same thing, the effects pallette stays open, but the editor closes. I never remember this behavior in XpressPro. To work around a mapped the effects editor to a mouse button, so i only have a quick finger click to restore.
Hope all is well with you,
Hi Brad:
That's strange because I had the effect editor tool keep popping up in my "edit" toolset...I must have inadvertently done a "save current" with it open, because when I closed it and did a "save current" it stayed closed.
I may try rebuilding my user settings to see if that changes anything. I did customize my Effect Editor toolset and did a save current (more than once, maybe that is the problem) and switched from effects to source/record and back and all windows open, the editor just doesn't stay open unless I am parked on an effect.
rbradleyc:when I am in effects mode and click anywhere in the timeline
peace luca
I don't understand why it would do that, I still have my Effect toolset active and want to play back maybe the minute or so prior th the effect I just added to get a feel for the timing. Then if I need to change anything in the effect I have to re-open the editor. I think it should stay open until I switch my toolset.
Sorry luca, I just re-read your post. In my system the editor doesn't just clear, I would expect that, but the window actually closes and I have to re-open it. Thanks for your input.
rbradleyc:In my system the editor doesn't just clear, I would expect that, but the window actually closes and I have to re-open it.
Is it onlyonly when you hit "timecode line"? That's is the only time mine disappears.
BustedFlush
When I choose my effects toolset, which I have customized with a large effects monitor and tools on the composer monitor, I can click anywhere in the interface including the time code track and never leave the effects mode.
