Latest post Tue, Jan 6 2009 5:17 AM by Ssnygg. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Dec 25 2008 6:49 PM
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 331
    • Points 4,300
    Overcoming AVID Import Limitations to JVC HD110 files
    Importing JVC HDV video files into MC has always been problemmatic for me. I always get the following message: Exception: DIOTSPParser::Parse-BufferSize(280576) is invalid File: \Devices\MPEGParser\src\DIOTSParser.cpp Line:483
    As a workaround I've used Cineform to transcode my native m2t files to avi before importing, as I've reported on this forum.
    As an alternate workaround which keeps the m2t format, I've been able to import my native m2t files into ProCoder and, using Procoder, export back to m2t. The process happens extremely quickly as no transcoding is taking place. The resultant ProCoder m2t file will then import into Avid without problem.
    Media Composer 4.03 on Win 7 64-bit and XP Pro SP3 - Intel x48, dual core quad 6600 - 8Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Sat, Dec 27 2008 1:46 AM In reply to
    • Swil
    • Australia
    • Posts 457
    • Points 5,860
    Re: Overcoming AVID Import Limitations to JVC HD110 files
    Woah that sounds good. What framerate are you using?
    Where do your m2t files come from? Do you use a HDD recorder or are you capturing from tape to an external app?
    Does your audio stay in sync once you've imported into Avid? That's the key problem I keep hitting...
    Core 2 Quad Q6600 4Gb RAM 512Mb GeForce 9800 GT Media Composer 3.0 Windows Vista 64 [view my complete system specs]
  • Sat, Dec 27 2008 2:06 AM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 331
    • Points 4,300
    Swil:
    1-24fps
    2-m2t files come from HDD recorder, firestore FS4-HD
    3-audio seems to be in sync. Only did a short test file and all looked well.
  • Mon, Dec 29 2008 2:40 PM In reply to
    • strimps
    • Chicago, IL
    • Posts 63
    • Points 715
    cuervo-
    have you found anyway to pull working 24p m2ts  w/ pulldown?  Reason being i'd like to be able to have footage w/ the 24p look, usable in 30i project (to mix w/ SD 24p footage previously shot for clients).
    xw8200 hp 2x 3.6 xeon 3 gig ram 3450 nvidia grfx card 500 SATA II internal (hot swap bay, archive) 73 gig scsi boot drive 1 TB WD external HD (back... [view my complete system specs]
  • Mon, Dec 29 2008 3:19 PM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 331
    • Points 4,300
    strimps:
    cuervo-
    Procoder will produce 24fps with pulldown m2ts files.
  • Tue, Jan 6 2009 5:17 AM In reply to
    • Ssnygg
    • Joined on Tue, Apr 11 2006
    • Allentown PA
    • Posts 177
    • Points 2,130
    What's your workflow?  I just tried the procoder.  When I went to tanscode from the JVC files - actually from Liquid - the files were in three parts (video and two audio) Transcoding a half hour clip left the audio clips one second longer (?) (or shorter, I forget).
    -Spencer
    I have several systems. 1-Liquid 7.1 service pack 1 1-Media Composer ver 3.0.5 1-xpress 3.5.4 pro pack 1-mac Express 2.2 AB/VB Targa set up The Liquid... [view my complete system specs]
